Stock screw isn't long enough for open element
Old Mar 5, 2003 | 05:41 PM
Kao91's Avatar
Hello,
I purchased the generic summit open element air filter, and installed it last night. I was, however, forced to put the lid on upside down because the stock screw wasn't long enough for it to go rightside up. How might I extend the screw so that it can be rightside up?
I do want to be able to put the stock housing back on in the event that I need to -- so only non-perminant solutions please.
Old Mar 5, 2003 | 07:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i think you are gonna have to bend some thread all or somethign
maybe get one from a TBI truck?
Old Mar 5, 2003 | 08:44 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
When I put mine on I had barely any thread coming through the top too, so I just spun the whole threaded bolt counterclockwise and it raised up enough to screw on the wing nut.
Old Mar 6, 2003 | 05:04 AM
jagone's Avatar
My screw wasn't long enough until I took the spacer ring off. Try that. Now the screw is actually a little too long and I have to put some spacers washers between the wingnut and the lid just to get a complete seal.
Old Mar 6, 2003 | 11:41 AM
deadtrend1's Avatar
go to thew autostore ... buy the air cleaner threaded shaft in the spectre aisle. Then put that into your tbi bolt hole.... bend a 90* one way, and then another 90* like the tbi one is. Install air cleaner .... cut away excess thread.
customblackbird
Aug 15, 2021 10:16 PM
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
wruiz
Aug 13, 2015 09:07 PM
