No start...
Old Mar 15, 2003 | 03:40 PM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
No start...
Hi Guys,
Here's my problem(s):
My car is a 1983 Trans Am 25th Anniversary Daytona Pace Car Replica with the Crossfire engine. Last fall as I was driving the engine died and would not start again. I did some trouble-shooting before winter hit, then parked it in the driveway under a car cover until recently. My trouble-shooting last fall showed that I was not getting spark - the engine turned over freely, I could see the injectors squirting fuel, and no codes on the computer. That's as far as I got, until today. Today I trouble-shot the electrical system and found the coil was bad. I replaced the coil, then tried to start the engine. Still turns over freely, but now the injectors are *not* squirting fuel. I am also not getting *any* idiot lights when I turn the key to the ignition position, and therefore cannot tell if I have any trouble codes or not. Neither injector is squirting fuel. I can also hear the fuel pump run when I first turn the key. It sounds just like it did when the car would run... I'm gonna hit the books again and see if I can figure this out, but if anybody has any suggestions, I'm all ears! Thanks,
Rob
Old Mar 15, 2003 | 08:05 PM
steve8586iroc's Avatar
You might check the ignition module. Have you put the old coil back in to see if the injector start working again?
Steve
Old Mar 17, 2003 | 12:34 PM
ops32's Avatar
Haven't tried reinstalling the old coil. I also haven't messed with the ignition module. I think the coil check was third in the trouble-shooting list, so that's where I stopped and replaced the coil. How does this stuff affect the fuel system?
Thanks!
Rob
Old Mar 17, 2003 | 09:20 PM
In all reality the coil shouldn't effect the fuel delivery but the ign module sends the electrical pulses the ecm needs to calculate the injector pulses. Something like that.
Steve
Old Mar 18, 2003 | 01:52 PM
ops32's Avatar
Hummm... OK, thanks for the info. I'll check the module.
Rob
thekurlyone
Sep 30, 2015 12:54 PM
nathan2003
Aug 4, 2004 12:14 AM
shapeshifter
Sep 20, 2003 12:09 AM
Knyghtmare
Jun 15, 2003 09:10 PM
Drowned
Dec 8, 2001 05:58 PM
