Bad Fuel Pump
Old Mar 16, 2003 | 01:36 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Bad Fuel Pump
I think I have a bad fuel pump now. After doing all my motor mods and turning up the psi to 12-14psi I think it's done. Yesterday when I started it up to do some data logging it only ran at 8 psi and it through a Fuel pump relay failure error code in winaldl. I think I'm going to buy the Walbro 255 for 93 bucks and I've got 350 injectors on the way. So I think this will solve my problem, I may get a new pump relay too since that's part of the system.
It lunges and surges real bad from a stop when i go wot, it'll sit there choking for about 10 seconds before it picks up and takes off.
Old Mar 16, 2003 | 03:07 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
check the filter
Old Mar 17, 2003 | 08:56 PM
87Formula4bbl's Avatar
Car: '87 Formula
i just installed a new fuel pump and i had the same problem as u did until mine went complety out. I did it the easy way by cutting the trunk. Prolly wouldnt do that again if i ever have to.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
