tbi fuel pump pressure
Old Mar 21, 2003 | 12:25 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Just curious about what the pressure is suppossed to be coming out of a 305 tbi fuel pump.
Old Mar 21, 2003 | 09:09 PM
25THRSS's Avatar
It varies from car to car, but I think 7-13 psi is within factory specs.
Old Mar 22, 2003 | 12:46 AM
JPrevost's Avatar
Car: 91 Red Sled
The fuel pump isn't what's regulating the pressure until you get past ~15psi. The regulator should be controlling the pressure but once you crank up the pressure the pump will have a fit.
Old Mar 24, 2003 | 12:27 AM
RSpeed's Avatar
So it's possible to bypass the stock inline filter with a rubber 50psi fuel hose? Reason I ask is because the stock fittings on the filter are frozen and the metal line starts to twist when trying to remove the fittings,so I can't change the filter. Since I switched over to carb a while back,I installed an aftermarket filter right before my carb,so I'd still have a filter on the fuel line after bypassing the stock filter. Just want to make sure the pump isn't putting out too much pressure for a temporary rubber line.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
