Aftermarket coil?
Old Mar 24, 2003 | 07:18 AM
CrispyClutch's Avatar
Aftermarket coil?
Whats the story on these? I thought the coils are built into the distributor.. Can someone tell me whats a good inexpensive aftermarket replacement,and where and how does it hook up?
Old Mar 24, 2003 | 10:35 AM
After some thought, I'm just going to get a stock replacement.
Do the coils go bad after a while? Could it possibly be causing my rough running troubles?
Old Mar 24, 2003 | 10:49 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
the MSD Blaster coil is what I've got. My old coil was arcing and I noticed a SOTP difference when I installed the Blaster. The coil is just under the air cleaner on the back side of the intake manifold. Unless your old coil is shot or arcing to the motor I don't think replacing it will help you with your rough idle. That's more likely to be plugs, wires, timing, or possibly your cap and rotor.
Old Mar 24, 2003 | 12:43 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Im running the MSD too, I like it. I noticed it smoothed out my idle, but I dont think it did anything to add power though.
Old Mar 24, 2003 | 01:59 PM
knoxbonnie's Avatar
The MSD Blaster Coil will only show you improvements when you get into higher RPM ranges like over 6000 RPM (I think) when your stock unit can't keep up.
I have the MSD Blaster on mine though, didn't notice any difference in power, but it looks and feels like a better build unit than the OEM I had on it.... if nothing else, you may get longevity from it.
Old Mar 24, 2003 | 04:29 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I too have an MSD blaster coil, and noticed a sotp difference past 4,500rpm where the stock one dies off. Maybe my stock on was on it's way out, i dunno. But for $40, i still feel it was the best $$ to power gain. Can't argue with increasing the powerband by another 500rpm.
thunder57
Nov 7, 2015 02:28 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
Jlanz55
Sep 6, 2015 03:05 PM
