Code 44
i'm just looking at code 44 in the gm manual and its stating
(1) check the ecm wiring connections, particularly terminals 15 & 8
(2) check for vacuum leaks at the tbi if tbi equipped, vacuum hoses or the intake manifold gasket and if none of them are the problem replace the O2 sensor , so you must have a lean exhaust
