runs bad
Old Apr 6, 2003 | 09:02 PM
fahq's Avatar
runs bad
I have a 93 chevy pickup with a 305tbi. When it is cold it misses a little bit but once it gets warm it starts missing really bad and bacfires through the intake. Any suggestions
Old Apr 6, 2003 | 09:24 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Oxygen sensor, or bad injector(s), or fuel pump.
Old Apr 6, 2003 | 09:37 PM
fahq's Avatar
I didn't check my o2 sensor. can it be bad with no codes?
Old Apr 6, 2003 | 09:45 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
You never know, they disabled different codes for different years. My 89 never through a code when the O2 crapped out.
Old Apr 6, 2003 | 09:47 PM
fahq's Avatar
did you have the similar problem
Old Apr 6, 2003 | 10:01 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Our motors a probably way different, but once it warmed up and went closed loop (when the ecm reads from the O2 , rather than open loop when it just goes off tables in the chip) it would chug, and spitter and want to die.
Another problem (especially this time of year) is badly corroded distributer. Salt from the winter roads corrods the points.
Old Apr 6, 2003 | 11:47 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Replace the fuel filter!!!
You'd be suprised what goes wrong when that thing gets even a little clogged up, trust me I know.
If it still gives you hell after that then give the ignition system a once over to check for anything bad in the distributor, if that checks out then try the o2 sensor, its a cheap and simple, sort of, thing to replace. It's probably worn out anyway, their sensitivity greatly reduces over time. Beyond that its most likely a bad pump not giving enough fuel to the TBI. With the engine running look into the TBI bores and see if the fuel spray is even and not sputtery.
I hope I didn't loose you in there somewhere, good luck!
Old Apr 7, 2003 | 03:07 PM
fahq's Avatar
I did replace the fuel filter. I did check the injectors and fuel pump
they are fine. Do you think it could be the ignition control module?
Old Apr 7, 2003 | 03:35 PM
Dan W's Avatar
I had similar problems due to a bad temp sensor.
Old Apr 7, 2003 | 06:07 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
If its the modual, vehicle usually won't work at all.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
