safe to make own spacer?
Old Apr 9, 2003 | 11:59 AM
SlowMaro's Avatar
ok , i got a weird idea and seeing how im cheap, i decided to make my own 1 inch spacer....i used the gasket as a template and it came out GREAT..i wish i had a digi camera to show yall....but the question is, ..is it safe?? and i used plywood...is that bad or does it matter???
Old Apr 9, 2003 | 12:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: safe to make own spacer?
Eventually it will become fuel soaked. Can extend its life by painting it with the hot fuel proof paint found in hobby shops for use on gas airplanes.
RBob.
Old Apr 9, 2003 | 12:46 PM
SlowMaro's Avatar
so was this a bad idea?? i mean...will it work lol....i figured ...wood....reduces heat to tbi...only thing i had was 1 inch thick plywood laying around....
Old Apr 9, 2003 | 02:07 PM
steve8586iroc's Avatar
It will work ok. Rbob was just saying that you need to coat it with something fuel proof to keep it from soaking up gas over an extended period of time.
Steve
Old Apr 9, 2003 | 03:50 PM
SlowMaro's Avatar
dude, youll never believe what just happened, before i saw that.....I FORGOT THE RETAINER>.....hit the gas VROOOOOOOOOOOOOOOOOOOOOOOOM
me- " AHHHHHHHHH NOOOOOOOOOOOO WTF!!!!!!!!!" heh, nailed the brakes, ..didnt help, hit the e brake, ...stopped he car * after i almost nailed someone* and threw it in neutral quick like and hit the key.....fixed it, cranked it up, glug glug glug black smoke out the tail pipes and white smoke out the manifold..NOOOOOOOOOOOOOOOOOOOOOOOOOOOO ....let it si for a min...cranked up...ran fine...no smoke...im like "uhh thank ***??"
Old Apr 9, 2003 | 04:09 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
i had to fabricate a spacer to clear my EGR and used teflon at first, but eventually it cracked because i didn't have enough material around the bores. If you want a sure bet, stop by a local machine shop with a template and have them punch one out of aluminum, I made my own and it works nasty.
Ty
Old Apr 9, 2003 | 05:21 PM
jlbolin's Avatar
ill try to get a pic of mine for you its made out of phenolic 1 inch thick no probs with soaking in fuel and stays cooler than aluminum.
customblackbird
Aug 15, 2021 10:16 PM
Grant2k
Jul 10, 2018 04:01 PM
deracer
Apr 11, 2016 12:04 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
BlackBoulder
Aug 11, 2015 11:15 PM
