knock sensor is where?
Old Apr 14, 2003 | 08:39 PM
Charlo's Avatar
A search told me it is on the passenger side of the block, I have looked and see none. Maybe the motor I picked up had it removed. Where on the block should I look? Near starter? on front near smog pump?
Charlo
Old Apr 14, 2003 | 10:44 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
It's located on the passenger side of the block above the oil pan and in front of the starter.
Old Apr 15, 2003 | 09:49 AM
GKK's Avatar
GKK
I'm at home now, here's a picture:
Old Apr 17, 2003 | 01:19 AM
Charlo's Avatar
So I looked all over near the starter, nothing at all. There is a single bolt, metric I think but it has no markings on it at all. None of those lines for grade and no 9.8 or somthing. I was gonna take the bolt off to see if knock would thread into it, but is is rusted on. I was afraid of breaking off the head so its soaking in liquid wrench right now. It right near the starter about solonoid level. Thanks for the pic GKK.
Charlo
Old Apr 18, 2003 | 12:18 PM
Charlo's Avatar
So I pulled the bolt out. Part of the treads broke off in the block . I drillied it and got that out with an easy out. After that I was cleaning the threads with a tap when coolant started pouring out of the hole. Did I drill to far getting the old thead out? Or did I find some kind of drain plug rather than the knock ensor location? The treads match the knock sensor perfect. Please help?
Charlo
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
