StealthRam MFPI intake manifold
Old Apr 24, 2003 | 08:01 AM
Hawk4Me's Avatar
Hey all im new to this forum and got a question. I recently bought a 1991 firebird formula and was wondering if this intake manifold shown here-->StealthRam MFPI intake would fir my 91 305 tbi. I know it won't clear the stock hood but what if i got the hood and ram air kit shown here-->RamAir Hood kit . That should add up to around 80 ponnies for just over $1200 any input on this would be appreciated.
Old Apr 24, 2003 | 08:11 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well, it wil "fit" as in bolt on to, a TBI engine, but the computer won't support the MPFI, you would have to switch to a TPI computer system, or buy the whole kit from holley that includes stealth ram, command 950 computer system, injectors, sensors, ect. that runs around $2300.
Old Apr 24, 2003 | 09:16 AM
Hawk4Me's Avatar
Dewey316 do you have a link to this kit your talking about. That doesn't sound like to bad of a deal but $2300 is alot of cash. Do you know of anyone who has installed this kit, and can you tell me if they are very satisfied with the results?
Old Apr 24, 2003 | 09:20 AM
Dewey316's Avatar
Car: 1990 Camaro RS
the only person i know with a steath ram has a 92 1LE , he put the stealth ram on with a comp-cam, and trickflow heads, he is makeing 425 or so HP.
i don't know anyone who has installed the full 'Kit' you would probably be able to do the TPI computer swap for much cheaper than the full holley kit.
here is the link to the kit at summit.
http://store.summitracing.com/produc...earchtype=ecat
Old Apr 24, 2003 | 09:41 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i was under the impression that the stealthram kit came with a computer and harness....am i totally wrong?
Old Apr 24, 2003 | 10:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
the 'Kit' does.
what they sell at thunder, is the intake, plenum, and runners. thats all.
Old Apr 24, 2003 | 10:50 AM
JR305's Avatar
I have done the swap from TBI to Stealth ram on my 92 RS. I just bought the manifold, plenum, fuel rail kit from thunder racing for $480. Found a 91 speed density harness and ECM for $120. Picked up some Ford 30 pound injectors for $160 off eBay. Then you need a throttle body, I have a stock 48mm that I got for $40 but I went and bought the Holley 58mm TB for $375. You will also need a high pressure pump, I chose the Holley unit for $150. Then you will need little things, sensors, air filter, ducting for the air intake, different fuel lines, some new vacuum lines, and maybe a dual fan setup.
But I doubt you will gain anywhere near 80hp probably more like 30. The TBI heads and cam are not high rpm pieces like the stealth ram. I would look at new heads and cam before I swapped to this manifold or you will be disappointed.
Here is a pic of my new engine.
Old Apr 24, 2003 | 09:34 PM
HIBERNIS's Avatar
the holley stealth ram is priced at around $300 for the tunnel ram intake, and the plenum. A fuel rail kit with a nonadjustable FPR for $200 and the kit with the adjustable is priced at $250.For
85-86 f bodies with the coil on cap HEI distributor, need to swap the cap and coil to a small cap,and externally mounted coil. The thermostat housing needs to be changed to one with a 1 inch water neck and the hose also needs to be replaced. Total cost for this setup including gaskets,silicone,fuel fittings etc....... is $655.
I got this quote from an article in the may 2003 issue of gm high tech performance mag where they installed this setup on an 86
Iroc camaro. Check that article out, it should be very helpful.
Old Apr 24, 2003 | 09:45 PM
steve8586iroc's Avatar
You might also want to check out the tpi board, they have been descusing this subject for a while now.
Steve
Old Apr 25, 2003 | 12:42 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Yea do a search for the Stealth Ram FAQ, there's a big list of just about everything you'd want to know about it
If anyone is curious, I emailed Holley and they said a Vortec version is supposed to be comming out sometime this year. GMHTP also reported that a version with about a 1/4" shorter tunnel would be comming out to fit under all 3rd gen hoods without modification.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
