4 bbl tbi
Old Apr 29, 2003 | 08:45 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
4 bbl tbi
http://cgi.ebay.com/ebaymotors/ws/e...&category=33558
i'm spending wayyyyyy too much time on ebay!
in gm high tech performance's project magnum series, they used a harness special harness which let them use a dfi for engine management and the factory computer for the smog control.
couldn't you do something similar with a 4bbl tbi setup? the aftermarket computer would offer much better tunability, wouldn't it?
Old Apr 30, 2003 | 04:36 AM
JPrevost's Avatar
Car: 91 Red Sled
Re: 4 bbl tbi
You'd be suprised how much tunability is built into the stock computer. There are more tables and constants in a stock computer to control basic engine features then in even the most concurent dfi kits. One example: A/C on desired idle speed, AFR in open loop vs coolant temp, choke, and manifold vacuum, there is also highway mode and complete TCC control. The only advantage to a aftermarket is that they usually have a few little extras like shift light and real-time higher refresh rates.
The 8746 ecm and the 7747 (any c3 for that matter) can use the lockers diy'er project to get 15+fps of data AND has extra A/D inputs for stuff like oh say a wideband o2 .
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
dusterbd
Sep 29, 2015 08:40 AM
