305 HO or not...
Old Apr 30, 2003 | 09:02 PM
Tweezer's Avatar
305 HO or not...
Hi guys, i got a 88 trans am
I wanna know if its a 305 HO or not,
I saw something the other day on this board about the RPM range but now i cant find it anymore. Where can i look to know?Could anyone help me plzz.
Old Apr 30, 2003 | 09:24 PM
Black363IROCZ's Avatar
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
88, 305 TPI w/5-speed = the H.O. model. the TBI, carb, and 305 TPI autos aren't.
Old Apr 30, 2003 | 09:30 PM
vjo90RS8's Avatar
Car: 2002 Z28
305 TBIs are definately no H.O.s, unless you call 170HP and 255 ft-lbs high output.
Old Apr 30, 2003 | 09:38 PM
Tweezer's Avatar
ok thank you
Old May 1, 2003 | 09:54 PM
iroc22's Avatar
Careful. What he's probably referring to here is the 83-86 L69 H.O. motor; which is carb'd.
Tweezer, the redline should be at 5500 for the H.O. 305.
Old May 2, 2003 | 11:37 AM
Car: '88 IROCZ
umm, I believe he said he had an '88 Firebird, in which case there was no L69 as you pointed out, so unless someone actually took the time to swap in an L69, he's got an LG4, LO3, or LB9 peanut cam, which are LOW PO at best.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
