Speed Limiter
Old May 3, 2003 | 09:52 AM
vrooom305's Avatar
Speed Limiter
https://www.thirdgen.org/newdesign/tech/unlimited.shtml
Ok, I've read this article and was wondering if there is any noticable gain? Is it worth it in terms of it's pro's and con's? How bad will it be if I permanently disconnect it? I't claims that I'll be able to go faster than 110 MPH, is this true? Can anyone post pics of where this is actually located?
Old May 3, 2003 | 11:16 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you go that route, once you flip the switch your speedo will show 0 MPH.
i have mine disabled via a custom prom, for $30 you could get that tbicips guy to burn you a chip with the speed limiter disabled.
Old May 3, 2003 | 02:56 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
or you can take 30 seconds and unplug the speedo from the transmission
Old May 3, 2003 | 03:11 PM
vwdave's Avatar
And you'll have no speedo.
Old May 3, 2003 | 03:40 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
Re: Speed Limiter
Not sure what your asking, but there is no power gain at all.
Have a nice day.:lala:
Old May 3, 2003 | 08:08 PM
vrooom305's Avatar
Re: Re: Speed Limiter
yeah I guess I was talking about power gain
Old May 3, 2003 | 09:11 PM
25THRSS's Avatar
just remove it from the chip.
Old May 4, 2003 | 12:19 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
It doesnt matter because there's no reason for a 305 tbi to go faster than 35 mph.
Old May 4, 2003 | 12:22 AM
JPrevost's Avatar
Car: 91 Red Sled
And while you're there, fix all the "creative coding" GM was forced to use to pass emissions.
Old May 4, 2003 | 07:35 PM
vrooom305's Avatar
do you mean chip burning?
Old May 4, 2003 | 07:47 PM
25THRSS's Avatar
Yeap. If you don't really know much about it or have the resources then go here. He is a good guy and can burn you a custom chip for your exact car. The best part is it's only $30!
http://www.tbichips.com/
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
