Open element Q's
Old May 6, 2003 | 11:28 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Open element Q's
Maybe I missed something, but I haven't seen anything about plugging the hole in the exhaust manifold after removing the preheater hose and thermac device, and does this effect emissions legality? If so, is there a way to still use these with an open element, like getting longer ducting and sticking it to the side of the air filter? Just an idea.
Old May 6, 2003 | 11:32 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just pulled the hose off mine and did away with it. I heard it was better to take it off anyways, robs horsepower. i dont think it has anything to do with emissions
Old May 6, 2003 | 11:40 PM
Engine: L98 and L03
what I'm asking about is the gaping hole in the exhaust manifold
Old May 7, 2003 | 12:00 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
that hole is not in the exhaust manifold itself its just a piece above the manifold. What its purpose is is on cold starts it will transfer air from directly above the exhaust manifold which will obviously be hot right into the intake to warm up the engine quicker. You don't need to do anything about plugging it.
Old May 7, 2003 | 12:10 AM
Engine: L98 and L03
What about its effect on emissions?
PS: Sorry if I annoyed anybody with this question, but I couldn't see how a hole in the exhast could just be ignored.
Old May 7, 2003 | 12:40 AM
BronYrAur's Avatar
Engine: 305 TBI
Don't worry about annoying anyone on here questions are what we're here for. For emissions you are goign to want to swap your stock setup back on when you have to take the test because if you have to pass a visual you need it and actually in my case I failed the sniffer with an open element then put the stock one back on with a new filter and passed.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
