Tell Me if im crazy
Old May 7, 2003 | 10:35 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Tell Me if im crazy
Ok i have a Firechicken With tbi with an ram air one hood i was making my own custom intake system. I was gonna take off the thermac and then rotate the aircleaner box then use the ram air system for a tpi would that work if i didnt use a filter at the begining or would it trap water durring driving
:lala: :lala:
Old May 7, 2003 | 11:22 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Most of the ram air hoods have baffles in them to prevent water from getting into the intake stream. Using the stock air cleaner wouldn't have any effect on water movement since it would have to go thru the filter and up into the TBI, not going to happen. If you're worried about water getting as far as the air cleaner a few holes drilled into the bottom of it outside the filter element should provide adequate drainage.
Old May 7, 2003 | 11:34 PM
Does it sound like a plasuable idea?
Old May 8, 2003 | 12:11 AM
25THRSS's Avatar
Sounds like it could work.
Old May 8, 2003 | 04:30 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
https://www.thirdgen.org/techbb2/sho...postid=1273723
Old May 8, 2003 | 07:12 AM
thats a cool idea now if i can shape it to go up into the "nose" of my ram air 1 hood
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
