need help very quick help
Old May 12, 2003 | 08:28 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
i hAVE an 89 camaro 5.0 tbi.i need to know the firing oder and i need a pic of where the #1 wire gos on the cap my car runs like **** because i dont know the firing order or were the first wire gos.help me out a pic will be wondeful to know were the first wire gos.my dis. cap only gos on one way help me!
Old May 12, 2003 | 08:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
firing order is cast into the manifold just behind the thermostat.
Old May 12, 2003 | 08:32 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
okay but which way does it go can u please send me a pic of were the first wire gos on the cap?
Old May 12, 2003 | 08:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
no i can't, i am at work :-(
turn the engine over til #1 is at TDC and then see where the rotor is facing, that should be the #1 position, then follow the firing order around.
Old May 12, 2003 | 08:48 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
WHATS TDC AND WHAT YOU MEAN TURN THE ENGINE HELP ME OUT I DONT KNOW MUCH
Old May 12, 2003 | 08:50 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
firing order for a sbc is 1-8-4-3-6-5-7-2
the number one spot is usually when looking at the motor,one contact off to the right..picture a clock
its roughly the 7-8 o clock position
well i tried finding a pic for you,but i cant right now.so if yo ustill need a pic,maybe someone else can post one for you,if not ill post one later.
Old May 12, 2003 | 08:52 AM
vjo90RS8's Avatar
Car: 2002 Z28
go spend a few bucks and buy either a clinton's and/or haynes manual.
Old May 12, 2003 | 08:54 AM
MarkB's Avatar
Engine: 383 -305
TDC = top dead center, which means when the number 1 cyl is at the very top of the cyl bore.
basically heres how i get the engine at TDC
simply pull the distributor cap,rotate the motor over until the timing mark lines up on your timing pointer,down on the harmonic balancer,when the marks are lined up,the rotor under the distributor cap should be pointed directly at the #1 spark plug terminal on the dissy cap.
need more help?
Old May 12, 2003 | 08:55 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
I HAVEA BOOK ITS A PEACE OF ****.OKAY SO IF IM LOOKING AT MY CAR IN THE FRONT THEN I LOOK AT MY CAP IT WILL BE THE 7 OR 8 ACLOCK RIGHT ?
Old May 12, 2003 | 09:16 AM
vjo90RS8's Avatar
Car: 2002 Z28
if you look at the engine from the front, #1 is the one right before 6 o'clock, then go clockwise with the firing order
Old May 12, 2003 | 09:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
it should be just after 6'oclock, not just before.
but your best bet is going to be to turn the engine over to TDC and line up your timing mark, and then you will KNOW where #1.
Old May 12, 2003 | 09:30 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
I DID THAT BUT MY CAR IS NOT SPARKING ALL CYLINDERS IS RUNS BAD AND WHEN ON GEAR OR WITH A/C ON IS SHUTS DOWN
Old May 12, 2003 | 09:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
did you find #1, and the follow the firing order around, and make sure you have them all in the right order?
if so, check other things, check for bad plug wires, bad terminials on the cap, fouled plugs ect.
Old May 12, 2003 | 10:14 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Maybe this will help
Old May 12, 2003 | 10:16 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
here you go
Old May 12, 2003 | 10:17 AM
1MEAN92RS's Avatar
Engine: LO3
hehe, what's that they say about great minds?
Old May 12, 2003 | 11:39 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
thanks alot guys but im also going to put my egine in top dead center to be sure were # one is atr thanks alot guys
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
