Failed Emmissions Again
Old May 17, 2003 | 01:16 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
heres what it says
READING LIMIT
HC 1.6220 0.8000 fail
CO 5.0333 15.0000 Pass
NOx 2.6072 2.0000 FAIL
so is there anything i should check i just replaced the spark plugs last summer and my dad acdiently put 87 instead of 92 but i still added octane booster and put the cat back on.
any help would be thanked!
Old May 17, 2003 | 01:18 PM
vjo90RS8's Avatar
Car: 2002 Z28
i actually heard that it is better to use a lower octane gas when getting your car smog tested.
Also, how old is your O2 sensor?
Old May 17, 2003 | 02:20 PM
tbfirebird's Avatar
Engine: ??????????
just barley 1 year
Old May 17, 2003 | 02:31 PM
vjo90RS8's Avatar
Car: 2002 Z28
do a search, there is alot of info about smog testing. Also, try tuning down your fuel pressure if you have made your regulator adjustable.
Old May 17, 2003 | 08:20 PM
badxs's Avatar
how old is the cat and how did you remove and reinstall the cat??
ive seen this a lot on gm's?
Old May 17, 2003 | 09:05 PM
Boxeat2469's Avatar
Want to pass no problem for under $5 ? Heres what ya' do;
run your gas tank down to about 2 gallons of 93 octane. Add 4 bottles of Heat gas line dryer, you know the stuff in the little yellow bottles. Slosh the tank around good to mix it all up. Now go to the smog test and pass! After you pass, drive off those couple of gallons, and go fill up with your normal fuel of choice. I know first habd this method works. I've done it on my own cars. Heat is basically alcohol. Alcohol doesn't produce hydrocarbons as a byproduct of combustion, so the emissions will come out squeaky clean.
Old May 17, 2003 | 11:07 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
You could also try bumping your timing up a little bit. I failed at zero degrees but passed at 6 degrees advanced.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
