Injectors
Old Jun 1, 2003 | 12:08 PM
MericanMuscle's Avatar
Injectors
First off i have a 89 LO3 with 3inch exhaust all the way back, Lt1 cam, double roller chain, performer tbi intake, turbo city throttle body base with injector spacer, and pulleys. I have the gm adj. fuel press reg. on the way with the top down spring. Now with 65pph injectors what pressure do you think it should be set at at idle? Also are the 65pph too much for this engine or can the fp be adjusted enough to compensate? I also had planned to get some custom prom tuning in, is the regulator going to make it tricky? Any help would be appreciated
Old Jun 1, 2003 | 01:55 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
65pph injectors are too big to run with the stock chip. They will work good for you once you get a chip custom burned for your application. As long as you do not continually change the fuel pressure, the regulator will not effect chip tuning as long as you pick a psi you want to run and stick with it, and burn your chip based on that fuel pressure.
Old Jun 1, 2003 | 01:58 PM
Sorry i meant vac. adj regulator, if that makes a difference to you
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
