new to tbi..need help
Old Jun 4, 2003 | 06:39 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
ok yesterday i bought a 88 formula and it was 305tbi....the car has 135000 miles.....what might i hafta replace sensor whise and stuff.....right now at idle it kinda chugs a lil and is sorta rough.....once in a while itll do a lil cough and a lil pop will come form the intake but that is prolly just timing...once in a while when i start it, it will die.....it doesnt slowy die like chug chug chug stall....but it almost just turnes itself off.....ignition maybe?.....my dads friend said i should replace the cat and o2 sensor......think thad help?
Old Jun 4, 2003 | 11:34 PM
Charlo's Avatar
Check your oil pressure quick.
Charlo
Old Jun 4, 2003 | 11:45 PM
25thanniversZ's Avatar
check or replace the egr valve probably never been changed, wont hurt just help,check IAC,timing,fuel filter might need replaced to,check the coil wires plugs cap rotor ect.......
Old Jun 5, 2003 | 01:45 AM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
im almost 100% sure that formulas wernt tbi. they were tpi. 305 tbi is just the base v-8
Old Jun 5, 2003 | 01:48 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Pretty much all models had the 305 TBI as an option, there were formulas that had TBI as well as Irocs.
Old Jun 5, 2003 | 02:00 AM
Car: 1992 Firebird
thats what i thought b/c my v.i.n said that mines a formula and so does my insurance but its not.i thought formulas came with 305 tpi and 350 tpi
Old Jun 5, 2003 | 02:43 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
You could get lo3 irocs, lo3 formulas, l98 formulas....
You could get about any motor in any model besides the GTA they only has l98s.
GM messed up I think.
They should have made 2 maybe 3 engines tops.
You either get a slow v6 or a l98. Thats my opinion anyways.
Having 5 or 6 different motor options was kinda dumb I think.
Old Jun 5, 2003 | 12:58 PM
Car: 83 Camaro
Transmission: th350
what would the oil pressure mean...think there could be a crack in the block?
Old Jun 5, 2003 | 04:26 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
I would first check timing then maybe take off your TBI and clean it up a bit. sensor wise. get a digital ohm meter and test everything... Do a search and your find the correct readings... TPS iac, are good places to start.. couldnt hurt to change plugs and wires and cap and 02 sensor
Old Jun 5, 2003 | 04:33 PM
Car: 83 Camaro
Transmission: th350
i was jus wondering bout the oil pressure cuz i thought that the gauge was maybe just broke cuz its at zero.....lol.....yeh.....at least i only paid 700 for the car so if it needs a motor its not a big hit on me or anything
Old Jun 5, 2003 | 11:07 PM
Transmission: 4l60e
ill sell you a lg4 with 70k miles for 100$
