Aftermarket Intake
Old Jun 5, 2003 | 09:42 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Aftermarket Intake
Are there any aftermarket intake manifolds or throttle bodies for the '92 305s? Ive seen some, but they all seem to be for trucks or bigger engines. Thanx
Old Jun 5, 2003 | 04:41 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
you can get them from anywhere, edlebrock makes good manifolds but there for carb's but all you need is the adapter plate for your TBI.
I'm getting teh edlebrock performer RPM
do a search there should be many hits for aftermarket intake manifolds
Old Jun 5, 2003 | 04:59 PM
vjo90RS8's Avatar
Car: 2002 Z28
Edelbrock Performer TBI, it will say it is for trucks but it is for any 305-350 TBI. EDL-3704 is the part number at summit. Or you could get a carb intake and adaptor plate. Just do some research, also, do you have emissions testing where you live.
Old Jun 6, 2003 | 08:32 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Nope no emissions testing. I live in the buttcrack of America.
So will the TBIs for the trucks make my car run like a truck or have any effects like that? Prolly build bottem end torque right?
Old Jun 6, 2003 | 08:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
personaly i wouldn't even mess around with a TBI manifold, they are expensive and not THAT much better than stock
the 4bbl intakes are much nicer, and then pick up and adaptor for it.
Old Jun 6, 2003 | 09:08 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Where can you get adapters?
Old Jun 6, 2003 | 09:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
holley makes one, youc an get through most any parts vendor
and turbocity also makes one i beleive.
there are probably others.
but if you go that route you need to be mindfull of hood clearance, because with the adaptor you are basicly adding a 1" spacer, so if you get a tall manifold, it may not fit with the stock hood.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
J-money
Jan 4, 2019 09:45 AM
Blue419
Sep 10, 2015 01:03 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
