All my tbi peeps if you've got nos on your car post a pic here!
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
If you've got nos on your tbi engine could you post a picture of the set up and what amount of horsepower shot are you using on the tbi engine and what did you do to use the nos.Also if you could where did you mount the switch?
!THANKS!
!THANKS!
I had a nitrous kit on my TBI a while ago unfortunately I did not take any pics. I was running the NOS kit jetted at 100hp, the 5153 kit I think. I mounted my WOT switch to the metal line that runs from the manifold to the brake booster and the activation switch underneath the ash tray. All I did before installing the kit was get a MSD digital 6 ignition box. It allows you to retard your timing when you engage the nitrous. You should be fine as long as you don't have your timing advanced too far and your car is in proper working order. Other mods at the time were a full exhaust and open element.
Car: A Camaro
Engine: Weak
Transmission: Weaker
I have JR's nitrous setup now
, I haven't run it yet, but the bottle's mounted in the spare tire well, the no2 line is run and the plate is hooked up, I just need to run fuel line and electrical. Unfortunately I'm in Wisconsin and the car is in Arizona, so I can't really show you any pictures or give you any advice as of now, but check the time registry in my sig to see what Camaroracer1992 and ZRated did on the bottle...it's nice
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
