hood feels like an oven
Old Jun 15, 2003 | 01:49 AM
CamaroRS91x's Avatar
Hey guys,
well today I finally came to the conclusion that my car is getting WAY too hot. When I first start her up.....she runs fast as hell. But after cruisin for about 20-25 minutes, I definitely lose horsepower. When I open up the hood it's realllllllllllllllllllllly hot. I am going to be taking off the guards at the bottom of the windshield (i was told that helps). I'm in the process of saving for a cowel hood too. I also went to Murray's to get an open element Air cleaner. I bought a 14" Edelbrock. Stupidly, I brought it all the way home to realize it was way too big for my K&N air filter. I have the stock air cleaner on it right now. I went back and they only had a 10"...too small..... Any suggestions as to which size open element air cleaner I should buy? Also, any suggestions to lose some of the heat would be greatly appreciated.. Thank you all so much for being so understanding to my newbiness
Old Jun 15, 2003 | 02:39 AM
25THRSS's Avatar
cowl hood.
Old Jun 15, 2003 | 05:01 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay um take off the rear hood seal but leave it if you dont wash your car by hand because if you go through a high pressure washer then ALOT AND I MEAN ALOT of water will get in there and if it ever rains really hard while your driving around at low speeds like 20 then some water will get in there but other wise i havent had any problems if i were you i would save up for the ram air hood but thats just my 2 pennies/
Old Jun 15, 2003 | 09:08 PM
Thanks for the feedback
I installed an edelbrock open element air cleaner today w/ K&N so I really want to get a hood w/ an air scoop. How much will this run me total and how easy is it to install? Thanks!!!
Old Jun 15, 2003 | 10:56 PM
pat12spe's Avatar
ASCD has a deal for the ram air hoods going for $435. Just call them up and tell them it's the summersale discount and they'll hook you up. I ordered mine last wed. and it's fast shipping. They said it should be here by either monday or tuesday. Looks real nice on the cars too. The camaro looks good with the ss hood, so you might wanna look into that. Hope this helps.
Old Jun 15, 2003 | 11:10 PM
25THRSS's Avatar
They look ugly, expecially on camaros. Get a cowl hood or an ss hood. The cowl hood will be the most functional for what you want to do (remove heat).
Old Jun 22, 2003 | 10:45 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
I took off the hood insulation...it helps retain heat..not what you want. I've no problems--ahven't noticed a big diff but it probably helps a little
Old Jun 23, 2003 | 12:03 AM
Honestly, although you say a cowl will work better, an SS looks soooooooo much better lol. How much heat difference is it by the way? And pricewise too. Thanks!!!!
Old Jun 24, 2003 | 01:41 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
wire your fan to a toggle switch and replace your thermostat with a 165 my car runs consistently at 185 in traffic and if i turn my fan on it gets a little under .
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
