Gas Pedal Stiff
Old Jun 18, 2003 | 08:27 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Gas Pedal Stiff
My gas pedal is very stiff and makes it hard to control the throttle (I have a manual car). Anyway to adjust the tension or something????
Old Jun 18, 2003 | 10:58 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Does it go back slow also or idle a little higher for a longer time?
If so, the throttle cable may be binding up from corrosion. Either that or the TV cable/linkage is binding.
Get under the hood and manually move the throttle. It should open pretty easy. If not, then your throttle return spring on the TB may be binding.
A shot of WD-40 should loosen it up for a little while, but the best way is to replace it.
The only other possibility (and it's happened to me) is the cable has worn its way through the housing/insulation. A common place is right near the firewall where it makes it's first bend.
Check all those and report back with what you find.
Old Jun 21, 2003 | 08:36 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
There are 2 cable things. One seems to be attached to the vaccum and the other I am not sure what it does. I had someone push the gas and it looks like only one pulls back. The other just stays there???????
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
