TBI to TPI swap.?
Old Jun 20, 2003 | 10:16 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
TBI to TPI swap.?
Hey, I was thinking about swapping my throttle body out for a tuned port. I know their is a lot of work involved, but do you have to change you fuel lines? Im pretty sure you have to change the pump, which is no problem, But if i have to change all the fuel lines then i might reconsider.
Old Jun 20, 2003 | 11:42 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont think you need to run new lines, you just need to reroute them to the fuel inlets on the tpi. If ya have any questions you can pm me.
Kevin
Old Jun 22, 2003 | 11:11 AM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Kevin
Kevin is right, you just have to get the hardline from the tpi and it will bolt right into your existing lines.
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
