Question about ports on heads
Old Jun 23, 2003 | 05:53 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I was changing my lifters yesterday and when I pulled the manifold off I saw that there were two small ports at the very back of the heads that were blocked off on each side , one of them fell off and I was wondering what those ports are for and what would happen if I left them open . Thanks guys
Old Jun 23, 2003 | 06:25 PM
JPrevost's Avatar
Car: 91 Red Sled
You're going to need to be a little more specific. Are you talking about the coolant passages and by blocked off are you refering to the stock intake gasket with the pinhole in it?
Old Jun 23, 2003 | 09:18 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yes I believe that it is the coolant passages, and I am not sure if its a part of the gasket because they shredded when I pulled the manifold off the blocks were just sitting there when the gaskets were off , but it looks like it could be apart of the gasket
Old Jun 23, 2003 | 09:21 PM
JesasaurusRex's Avatar
Theyre gold colored right? Well anywayz I cant help u cuz I changed my heads when i ripped my manifold off but im just tryin 2 clear up what it is ur talking about.
Old Jun 23, 2003 | 10:59 PM
25THRSS's Avatar
They are the coolant passages and you can leave them open. It won't hurt anything.
Old Jun 23, 2003 | 11:19 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Awesome , Thanks guys I appreciate you Help!:rockon:
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
