IAC = 0 ... vacuum leak
Old Jun 26, 2003 | 04:59 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
In ALDL a while ago, I noticed that my IAC reading dropped to zero after a while. Does this absolutely mean that I have a vacuum leak (or could it be ~normal)? If so, is it indicative of a particularly *bad* leak, or would any leak be sufficient to keep the computer from wanting to open the IAC valve?
Old Jun 27, 2003 | 10:31 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I found that most OEM stuff is setup up so that IAC at idle is very high (~40).
Have you turned the throttle stop screw in to open the butterflies up more? Opening the butterflies will make the IAC counts go down.
I'm in St.Louis...pm me we should meet up...
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 2, 2015 03:39 PM
