when we use nos do we need to upgrade fuel?
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i was wondering if buying a tbi nos kit will be any good ?it gives u a 100 shot,now cloud the stock injectors hold this extra 100 hp?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
run a wet kit so you dont' have to worry about the injectors.
bigest worry of mine would be the fuel pump, with our cars getting older, the fuel pumps are starting to get weak, and we were not blessed with great pumps to begin with. as long as you run a fuel pressure switch, you should be ok.
Car: 89 Camaro RS
Engine: 5.0 tbi
a fule pressure switch is what marks fuel pressure right?so if it gos down let go of the bottom right and yes the holley wet nos kit
Car: 1990 Camaro RS
no, and you dont' hold a button down for nitrous
this isn't the TFATF.
it is a switch hooked in, that will automaticly shut of the nitrouse if the fuel pressure drops below a safe level.
this isn't the TFATF.it is a switch hooked in, that will automaticly shut of the nitrouse if the fuel pressure drops below a safe level.
Car: 89 Camaro RS
Engine: 5.0 tbi
ohh okay but my freinds camaro he controls the nos by a buttom and he cloud let it go when ever he wants so what should i do?
Car: 1990 Camaro RS
do what you want, i would run a WOT swithc, wiht a window swithc, and FP switch.
but it is completely up to what you want to do if you want to use a momentery switch, that is your choice.
Car: 89 Camaro RS
Engine: 5.0 tbi
but cloud you use a swicth so that i cloud control it or is that a bad idea and should i leave the way it comes?
Car: 1990 Camaro RS
the kit will only inlude a WOT switch. that is the only way the kit will be activated , you would have to buy the other peices.
a WOT switch does what it sounds like, it activates at WOT.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
