hey what should i run with?
Old Jul 4, 2003 | 08:21 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
okay here are the list of mods going into my 89 5.0 tbi motor,
1.a pair of vortec 350 heads
2.edelbrock airgap vortec manifold
3.tbi adapter plate and some 350 injectors
4.100 shot of nos tbi system
5.custom chip
6.lt1 cam
7.1.5 or 1.6 roller rockers and new rods
the rest of my mods are in my sig remember i have a posi so what should i ran with all this?
Old Jul 4, 2003 | 01:23 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
With traction that would be a 12 sec setup. Make sure you mill the 350 heads down to keep compression where it is now. You'll need alot of custom tuning as well.
Old Jul 4, 2003 | 01:44 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i would run a bigger cam than the LT1 cam with that setup, but with the 100 shot, you could go 12's with a really good launch, and if the tuning is good.
Old Jul 5, 2003 | 07:02 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
wow 12 sec's thats crazy over parts that you get cheap.one ? what does mill down the heads mean?so with 1500 dollars which is 1000 to the engine and 500 to the suspension our 305 motors can run a 12 high thats awesome so whats the point of getting a 350 that i know easier power and quicker thats all and more realibility thats it
Old Jul 5, 2003 | 11:41 AM
Car: 89 Camaro RS
Engine: 305 TBI
Milling the heads mean shaving some metal off the bottom to make you combustion chambers smaller. The big reason why we're saying 12's is because of the 100 shot of nitrous. All motor (without nitrous) that setup tuned perfect might see high 13's. If you put 1500 into a 350 it would be faster because of more cubes.
Old Jul 5, 2003 | 11:43 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
You wont go anywhere unless you work on your suspension a lot and fuel delivery. Ask me, I know lol.
Old Jul 5, 2003 | 12:10 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well now i know what it means so yeah probably by december i will have my car done so i post it up in the forums what should i do to my suspension and my fuel delivery besides the 350 injectors?
Old Jul 5, 2003 | 12:39 PM
Car: 89 Camaro RS
Engine: 305 TBI
You'll probably want a Walbro fuel pump. The 255 seems to be the best choice. A ton of custom tuning to get the fuel curve right. Adjustable fuel pressure regulator w/ pressure guage.
Suspension, you'll want sub frame connectors, lower contorl arms, and a nice rearend setup with good tires.
Old Jul 5, 2003 | 04:00 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well imdoing my whole chasis stronger by putting subframes torque arm lca's panhard bar and drag launch spring with some slicks on stock iroc z rims.does the fuel pump go in the tank or outside?
Old Jul 5, 2003 | 05:18 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Just a thought, but what if he didn't mill down the vortec heads and dropped the compression down a little from stock. He may not lose that much power from the loss of compression and would be able to run the nitrous a little more safely, correct?
Old Jul 5, 2003 | 07:52 PM
Dewey316's Avatar
Car: 1990 Camaro RS
it is going to be a slouch (relativly) of the juice with the low compresion, he might be able to run a hair more nitrous with lower compresion, but on a stock bottome end, would you want to? the amount of nitrous you can safely runs also depends on the cam you are running, it comes down to cyl. pressure and dynamic compresion ratio.
anyway, i think he is best off milling the heads to 58cc chambers. but like i said, i would run a bigger cam, a holley 670 TB with the 350 injectors, and a walboro pump (this is a MUST with the spray, you need to have enough pump there so that when you add the fuel with the nitrous, you don't have a FP dive, and then goodbye pistons.) if he does that, he will then be into ALOT of tuning, but once it is tunes, with the spray, it could fly.
also, $500 dosen't go far in suspension. it will get you a tq arm, and a set of UNISTALLED sfc's. but do the best ya can with what you got you could get a tq arm, box your own lca's get a set of brackets, and SFC's. that would get you started, but it will be a little more than $500.
Old Jul 5, 2003 | 10:08 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well thats all good advice but 12 secs thats to much for me because i be happy with 14 flat or high 13's so what should i do?lets forget about the nos for now
Old Jul 6, 2003 | 01:20 PM
BronYrAur's Avatar
Engine: 305 TBI
If you're looking for just a 14 flat or so just do the mods you had listed but with a bigger cam instead and forget the nitrous that should get you to a 14 time.
Old Jul 6, 2003 | 03:32 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
yeah im gonna go all motor but im gonna shave down the heads to have high compression and then put the bigger cam so then i should ran like a 13.8 right?
Old Jul 7, 2003 | 06:10 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ummmmmmm i think like 14.5s an old wise tail says no no to 35o heads on a 305:nono:
Old Jul 7, 2003 | 06:44 PM
BronYrAur's Avatar
Engine: 305 TBI
That's why he's milling the heads down to decrease the combustion chamber size to keep compression where its at now with the current heads. Nothing wrong with adapting 350 heads to fit a 305.
Old Jul 7, 2003 | 09:07 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
will the vortec heads mount on to the same holes or do i have to drill new holes or not?
MustangBeater20
Oct 29, 2022 09:20 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
