How nuts am I?
How nuts am I?
I installed my 350 back in april. When I set the timing, I set it way advanced.
87 Octane
Stock heads and compression
LT4 cam
15* of initial timing.
I backed it down to 8*. Nastier sound, less power.
87 Octane
LT4 cam
Car: 2002 Formula Firebird
Transmission: 4l60e
To much timing thats for sure. You should be at 8* tops. Especially with 87 octane. I wouldn't run 8* unless I was running 93 octane personally.
I put a jumper wire between the 1 and 2 ALDL connector (top right most contacts.) The check engine light will start flashing, and I set the timing like normal.
8* is about right.
8* is about right.
Car: 91 Red Sled
When I ran that 13.8 at 102 it was with 93 octane and ~14 degrees advance. That was with the ANLU eprom. It SUCKS as far as timing is concerned. Just like the 5.0 mustang guys.....they advance the timing a lot and never look back. I since then put the total timing back down but added a LOT of timing just off idle. That was the biggest improvement.
Car: check
Engine: check
Transmission: check
8* is about right.
8* is about right.
May want to disconnect the EST connector and double check your setting. I would also be interested in your results if you try the EST connector vs. the A/B pins shorted.
RBob.
Car: The rs is no more :(
Engine: the 2.8L in my LT
Originally posted by joshwilson3
How do you change the timing? Any special tools required? Where do you change the timing at?
thanks
thanks
Email me at:
91rs4life@comcast.net
I will be happy to explain it to you.
That goes for all rookies. Just call me professor Howdoyudothat.
3.8TransAM
Sep 27, 2015 08:37 PM
