454 TBI help
Old Jul 17, 2003 | 04:40 PM
sniper_dsl's Avatar
Car: '93 Full-size Truck
Engine: 350 Vortec
Transmission: 4L60E w/ shift kit
454 TBI help
finally got my TBI today, and i've been noticing the differences with that of the 454 and my stock 5.7.
looking at the front of a TBI you see 3 places for your emissions hoses/plugs. My stock TB has one of the LEFT side and the two in the middle... this 454 TB has the left blocked off and has a slightly smaller hose fitting on the RIGHT side. it is labled with an 'S' stamped under it, while my stock TB has no label. (i know this sounds confusing i could provide a photo if need be)
does anybody know if its merely switched sides/hose size, or is it for a different line all together?
also the darn wire plug doesn't match up... any GM mechanic can splice in a new one, right? (i know there is a post about this somewhere...)
another thing... do you think my truck will be drivable untill i get a new chip programmed? off the line it might ping... but who knows what that extra air-flow will do to the computer.
thanks guys
Old Jul 17, 2003 | 05:25 PM
sniper_dsl's Avatar
Engine: 350 Vortec
The red circle is where the stock 5.7 has its hose connection, which is slightly bigger vs. the 454's connection on the right. (blue circle)
So is this the same connector... or should i not plug in things that might not belong? seems like it all dumps into the TB anyways... but i'm not exactly sure when it comes to emission hoses.
the ones circled in green are the same on both TBI's...
Old Jul 17, 2003 | 06:04 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Every one of those are just vaccum lines. Cut, splice, plug, and "T" in where needed, just get all your olf lines connected again.
About the wire plugs (TPS, and IAC) just go to any wreckers, the 454 tbi uses the same plugs as most gm cars (88-93). The wires on the new plugs will be the exact same color, so just cut the old plug off. If they charge you more than $5 for the pair, there ripping you off.
You won't need any tuning if you run you 350 injectors, Ideally you would want to raise the fuel pressure a couple pounds to match the increased air flow. 454 injectors will cause you to run way to rich.
Old Jul 21, 2003 | 07:34 PM
CamaroFreak85's Avatar
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
Can anyone tell me what order the wires go in from left to right on the IAC valve for the 454 tbi, I have a connector that wil work but its not color coded correctly.
Old Jul 21, 2003 | 07:46 PM
sniper_dsl's Avatar
Engine: 350 Vortec
It should be labled A-B-C-D... here is a link to a past post which should help a lot.... it guided me through it quite well.
https://www.thirdgen.org/techbb2/sho...hreadid=188744
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
