surging at idle
Old Jun 24, 2003 | 12:56 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
surging at idle
having problems with cold start and surging.
when you first start the car, surge is pronounced, surging between 700 and 900 rpm at idle during warmup. it doesn't sound like much, but it's noticable.
i give the car at least a 2 minute warmup at coldstart, but it still stumbles a time or two when i first drive it.
the surge is always there, even when warm, although it's less pronounced when the car is warmed up.
plugs, wires, etc are all recent. just replaced the egr valve to get it to pass emissions. power is fine, but mileage is poor: 12-14 in town, 24 on the road.
does anyone have any ideas?
Old Jun 24, 2003 | 01:59 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
It could be a vacuum leak, or maybe your IAC. Your MAP sensor could be bad as well. Are you getting any codes?
Old Jun 24, 2003 | 11:39 PM
Engine: L03 305 TBI
no, no codes.
aside from the idle and cold stumble, it runs fine.
Old Jul 16, 2003 | 08:10 PM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
My guess is that you need to have the throttle shaft bore rebushed. Spray some carb cleaner around the throttle shaft and see if the RPM goes up.
Old Jul 17, 2003 | 04:56 AM
91rs4life's Avatar
Car: The rs is no more :(
Engine: the 2.8L in my LT
Beleive it or not my TPS gave me the same problem. It didn't throw a code either. May have something to do with closed/open loop.
At least with the surging part.
With the stumble thing I wanna say check the color of your spark. If your spark looks orange in color you may want to replace the ignition coil. especially if you have over 100k miles on it.
Why? Because the only things an engine has to stay running when it is cold are fuel and spark. When the engine heats up, combustion is assisted through the aid of thermal heat hence the spark plug is not doing all the ignition. some of your combustion then comes from the heat of the motor itself. If you have an "orange" spark, you have a weak spark and may possibly be the reason it stumbles when it is cold and not when it is warm. Your spark should be a blue-ish or purple color. Try it at night. you see it best then.
Old Jul 17, 2003 | 05:04 AM
91rs4life's Avatar
Tell me, what kind of fuel economy are you getting? how many miles per tank? This will help to determine if it is or is not your coil.
Old Jul 17, 2003 | 09:15 PM
Engine: L03 305 TBI
i'm getting 12-14 in town ..... 24 on the highway
Old Jul 18, 2003 | 02:34 AM
91rs4life's Avatar
sounds decent. Check the color of the spark anyway and tell me what you find. In the meantime I will be pondering what else it could be. I assume this is a 5.0 TBI. correct?
Old Jul 19, 2003 | 05:00 PM
Engine: L03 305 TBI
yes sir ... 305!
Old Jul 20, 2003 | 12:03 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I had problems like that it turned out to be the EGR valve.
Old Jul 21, 2003 | 06:10 PM
91rs4life's Avatar
could also be the EGR solenoid. I can't remember what the test specs are supposed to be on a TPS. I know that reference should be 5 volts but, can anyone help me out here? I think his TPS may be bad and I was thinking hard about it, It's not common but, it could be the reason for both of your problems. If I can get my hands on the right multimeter readings I could tell you how to test it to make sure it is not your TPS that is faulty. I know you are checking for resistance but how much I forgot. I think it may be like 2-3 ohms of resistance....Now I need somone to help me. LOL.
Old Jul 21, 2003 | 08:51 PM
Engine: L03 305 TBI
i replaced the egr valve less than 3 months ago to get it to pass emissions
junior419
Apr 7, 2025 11:35 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
