????horsepower for my new motor???
Old Jul 22, 2003 | 06:15 PM
mpresme333's Avatar
hey guys wondering how much horsepower my engine is worth here are my mods, new 350 motor 1965-1979 between there honed stock pistons, heads are the stock cast iron heads, new steel roller rockers, compu cam .424-.454 lift, flowtech shorty headers, holley tbi 2 inch bore intake, holly tbi 670cfm with 50lb injetors at 13psi for now???and thats about it now i just need to figure out if i am going to use tyhe cop car caprice chip or spend the dreded 300 for a custom burned one has anyone used the cop car caprice chip on their setup let me no what yea think!!!!!!!
Old Jul 22, 2003 | 10:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
230, maybe 250HP or so if your lucky. That essentially looks like what i have, except i have a gmgoodwrench knockoff of the 70's two piece motors. I wouldnt waste any time on a chip unless your concerned about getting the best possible fuel economy. Mine does ok w/ the stock chip and 65 pph injectors since the power band is essentially an expanded version of the l03's. More power and torque, but generally the same shape.
Old Jul 23, 2003 | 10:31 AM
mpresme333's Avatar
hey dimented thanks for the input! do you think my 50lb injectors will do or should i play with the pressure a little when i get i t running? So you are running your stock 305 chip thats surprising i would have thought with a cam and stuff that you have to change ur chip, this is my everyday driver so i want to drop the motor and have it run with no major problems, and like i said earlier the tbi chip on tbichips.com is 30.00 for a cop car caprice with 65lb injectors! So maybe i should just try my luck on it, what do you think!!!! Thanks for your input man!!!!
Old Jul 23, 2003 | 10:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the real factor to look at is the cam duration and lobe seperation. those are what is really going to determine how much computer tuning will need to be done.
for $30 i would get a custom chip. but *I* think tuning it yourself is always a better way to go, spend $150 and burn to your hearts content. you will get a much better tune, make more power, and get better milage. it isn't that hard to learn how to do it, just read , read , read, and read some more, then get out and start tweaking with things, you can pick it up pretty quickly.
Old Jul 23, 2003 | 11:00 AM
mpresme333's Avatar
where can i get a chip customed burned cheap??if there is anyone who does that, my cam is not to bad it is a computer cam by crane called compu cam its .424 intake .454 exahust not to eratic, I would like ot learn how to burn but i have just this crappy computer and nothing else!! thanks for the input!
Old Jul 23, 2003 | 11:06 AM
Dewey316's Avatar
Car: 1990 Camaro RS
tbichips.com will custom burn i think, try e-mailing him.
like i said, the lift that you keep telling us, isn't what is really going to determine how computer freiendly the cam is, it is the duration.
Old Jul 23, 2003 | 11:17 AM
mpresme333's Avatar
the advertised duration for the cam 264*- 274*, but tbi he tells you the software to use but does not burn them custom so idn like i said i will probably try my hand at the cop car caprice chip!!!!!!!!!
Old Jul 23, 2003 | 12:40 PM
Car: 88 Camaro SC
Engine: SFI'd 350
its a flat tappet so im guessing thats around 205/215 @ .05 in lift. I was considering getting a similar one from crane, as well as the xe one from comp cams but decided on the edelbrock one because it has a more lazy ramp profile which probably flies better with the garbage valvetrain i have. A chip from tbichips would probably work but you should still consider dropping $200, getting the equipement, and doing it yourself. Youll never know what youll want to do with the car later on. The only complaint i have with mine is the fact that it runs realll rich at idle. When i finally get all the other stuff out of the way, im gonna go purchase the prom burning equipment and fix that.
Old Jul 23, 2003 | 12:44 PM
Car: 88 Camaro SC
Engine: SFI'd 350
see the tech articles on what to get. Most say that tuner C.A.T.S. is the best software out there but its a little pricey and you have to pay $20 for each ecm definition file, which reminds me that i still have to find out which ecm i have.
AussiePr0nCar
Mar 6, 2020 04:04 PM
hydrolic144
Sep 8, 2015 06:55 PM
scottmoyer
Sep 5, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
