want to know if this is posible
Old Aug 12, 2003 | 09:03 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
i have a 88 truck with a 350 tbi and it is blown up now will just the 350 tbi fit on my 305 or r they the same thing.and if it is bigger will it work? would i need to use the 350 manifold? thanks
Old Aug 12, 2003 | 09:21 PM
25THRSS's Avatar
They are the same thing
Old Aug 12, 2003 | 09:23 PM
mpresme333's Avatar
It will fit on their just fine but you would probably over fuleing the 305 the stock injectors for the 305 are around 44lbs the 350 are 50 lb at 13psi..unless you have done some mods to the 305 motor you would be runnign into problems using the 350 injectors, now the intake and the thorttle body unit will do, just buy injectors for it.............
Old Aug 12, 2003 | 10:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
correct, i think, i read that pretty fast...
Old Aug 13, 2003 | 12:33 AM
Car: 1992 Firebird
is the 350 and 305 tbi the same size or is the 350 one bigger??
Old Aug 13, 2003 | 01:47 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
The 350 and 305 units are exactly the same in every way except the flow rating of the injectors. That is the only difference.
Old Aug 15, 2003 | 06:53 PM
Car: 1992 Firebird
ok thanks
ninety1TAgta
Aug 17, 2002 07:43 AM
Stroke_This
Apr 9, 2002 04:38 AM
BPA
Feb 19, 2002 01:42 PM
