17111784 or 17112560 injector
Old Aug 13, 2003 | 04:34 PM
Gausy's Avatar
Hey, I am trying to figure out which of these part numbers is the 90# 454 injectors. I have done extensive searching on the site for the numbers but they always seem to come up with different ones than these.
Any help would be great.
Old Aug 15, 2003 | 02:03 AM
Gausy's Avatar
Come on guys, I have called more than one dealer with these numbers and they only come up as " injectors" with no application or flow rating. The 17111784 number was one that I picked up off the search, but the 17112560 number is the one the dealership gave me when I asked for the 1993 454 SS injector.
From what I hear there are both 80# and 90# 454 injectors so I want to make sure I am getting the right ones.
I have entered both numbers on www.gmpartsdirect.com where I plan on purchasing, but again there is no application only "injector".
Thanks.
Old Aug 15, 2003 | 07:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I have this:
Late 17112560 Blue/Black are 75lbs/hr static (1708430 * RPD)
Early 17111784 DrkRed/DrkBlue are 90lbs/hr static
However, I believe that the 17111784 's are really about 82 lbs/hr.
RBob.
Old Aug 15, 2003 | 10:51 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Here's what Dominic Sorresso once posted:
They're 190 bucks including shipping for the pair. At least that's what I paid for them.
Here's the numbers for the two injectors:
ml/cyc = milliliters per cycle
BW = Borg Warner
Application ............| ml/cyc | BW New | BW Reman | GM OE Number(s) | Standard
454 2bbl Truck ('89) | 124 | 57021 | 27625 | 17111784, 17111865 | TJ11 Red/Dark Red 80#
454 2bbl Truck ('92) | 129 | 57229 | (none)| 17091045, 17091046, 17112557, 17112567 | TJ27 Blue/Black 90#
Old Aug 15, 2003 | 03:17 PM
Gausy's Avatar
Thanks for the responses guys,
Unfortunatly one of you is saying the 17111784 is an 80# injector and the other says it is a 90# injector.
Kdrolt, that quote is one of the posts I had researched previously and the only number that came up valid for me when entering it on partsdirect.com was the 17111784 number. A bunch of the others came up as something to do with "body Kit's".
Again thanks for the response, but does anyone else want to take a shot at it?
Old Aug 15, 2003 | 03:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Unfortunately one of you is saying the 17111784 is an 80# injector and the other says it is a 90# injector.
Maybe you need to re-read my post. I have the 17111784's in my car now, changed from the 350 blk/org's (61-65 #/hr).
So, from experience, I am saying that the DrkRed/DrkBlu injectors are closer to 80 #/hr then 90 #/hr.
The text where I said "I have this:" is from someone that flow tested the injectors at 10 psi.
RBob.
Old Aug 15, 2003 | 03:47 PM
Gausy's Avatar
I didn't realize that when you said "I have this" that you meant you actually have the injectors. I thought the numbers you "have" were just what you had heard or been told.
The other guys post said that the 17111784's were 80# injectors but if you know first hand that they are the 90's (even though they don't quite flow that) then I will take your word for it.
Thanks for the help.
Martin
Old Aug 18, 2003 | 11:08 AM
kdrolt's Avatar
Engine: LO3, LO5
Here's another possibly useful source for pns & cross referencing of injector part numbers (p/ns or pn):
http://www.tomco-inc.com/Catalog/24f...%20-%20tbi.pdf
FYI, HTH.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
