bad MPG? or normal?
Old Aug 14, 2003 | 11:52 PM
ilikerocks's Avatar
bad MPG? or normal?
i am getting like 16 mpg and thats taking her VERY gently. i never go above 3k rpms! i have an 89 305 TBI with 5 speed...is bout 16 mpg right??? (and i do bout 60-70% highway)
Old Aug 15, 2003 | 12:26 AM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Currently i am getting 23. I was getting 18 with 90% hwy, but then found my 02 sensor to be bad. i also put in a stage one chip from tbichips.
Old Aug 15, 2003 | 01:16 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
something is wrong if you're getting that milage. My old automatic 305 use to get around 17-18mpg city and 25-27mpg highway.
Old Aug 15, 2003 | 01:35 AM
ilikerocks's Avatar
so where should i start? tune up maybe? or should i just start replacing parts such as O2 sensor and adjust timing(because i thinks its off)
Old Aug 15, 2003 | 02:00 AM
ilikerocks's Avatar
ah i just found out from the person i bought it from that my cat was gutted..could this be a problem? O2 sensor goes right before the cat right?
Old Aug 15, 2003 | 06:04 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
O2 sensor is just below the drivers side exhaust manifold, and a good running stock TBI 5-speed shoud get at LEAST 20 MPG avg. and can get over 30 on the hwy. Replace the O2 and give it a good tuneup, if you advance the timing a few degree's from the stock setting of 0 you will get a little more power and MPG out of it. A gutted cat is bad too, after my cat went bad I gutted it and MPG took a nosedive, It also sounded like crap, I replaced it with a straight pipe and MPG came back and it sounded much better.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
my86bird
Oct 23, 2015 12:20 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Stroopwafel
Sep 11, 2015 06:38 AM
