How many horsies do i gots?
Here's my set up.
'91 RS, starting with stock TBI 305. (170hp).
Stock thermostat. TH700-R4 and 2.73s.
To it i've added a 10"x3" Open Element K&N, blocked thermac and relocated IAT to firewall.
Then added Dynomax Super Cat w/airtube and Hooker Super Comp catback with Aerochamber and dual quad tips, yesterday.
Has anybody got, or had this exact setup and either:
Dyno tested it
Drag Strip Tested it and got an HP number, or
G-Tech Pro'd it?
How many ponies did i get? I'm not interested in guesses or manufacturers claims. I'm wondering if anybody has actually got test numbers on my set up.
If my next planned step is a 170* stat and a stage 1 TBI Chip, (looking for reliability and driveability on 89 oct, as well as power) would that be a good next move, assuming that my wallet's not fat enough for the LT1 cam and new heads?
Will my stock FPR and injectors handle the mods to that point, or will i have to convert to adjustable pressure?
Thanks for your patience and help in advance,
Christopher.
Dyno tested it
G-Tech Pro'd it?
Christopher.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well the high flow cat, cat-back, and open air element will yield you some nice gains. I would say roughly 15-20 at the fly and 10-15 at the wheels. You will see another solid 10hp to the wheels with headers. You should be fine with your stock Fuel pressure. Every TBi car is set differently from the factory but I had every single bolt on (minus any stage x chip of any kind) and the car ran great. I added an vacuum adjustable fuel pressure regulator just to make sure but it didn't do anything. You do not have to worry about injectors until you do heads and cam. I would save your money on the chip and put it towards headers. You will be happier that way and still be able to use 87-89 octane fuel.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have:
a 3" open element, drop base
IAT on the firewall
catback is OFF, so its like the most free flowing exhaust you can get with a catback.... the cat is still on there.
same tranny and gears
it dynoed at 152hp at the rear wheels:
pic of my dyno run: http://josh.swoca.net/board/MrDude/Dyno/Run1bigpic.jpg
on the 1/4 mile, i worked and worked on it changing the way i drove..
i found that by holding out each gear longer i got it down to a 16.0.. at a 3615lb race weight as it sits on the track ( i have a vert, with a stereo system and everything in the car)
according to the Gtech, my best 0-60 time is a 7.86 however, i think i can do much better... i only made 3 runds with it 0-60
hope that helps.
IAT on the firewall
hope that helps.
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
do a run with all your stero crap out of the car and the spare tire and jack and back seats.And if you donty use it the a/c out to.That should get you to the mid 15's.:lala:
Car: The rs is no more :(
Engine: the 2.8L in my LT
Ya know what else ya could do? gap your plugs to .022. I thought it sounded stupid I figured it would create a smaller spark and give more incomplete combustion but, i was wrong. Because the gap is smaller, the spark is stronger and actually ignites the fuel better allowing more complete combustion and increasing hp while helping to kill fuel economy
I got a consistent gain of 13 hp by doing that.
try gapping your plugs to .022. I thought it sounded crazy too but, it works. smaller gap = stronger spark. i gained 13 hp consistent. however my fuel economy suffered about 20 miles per tank
Car: 91 Camaro Vert
i did a run with the AC on for the heck of it... ran a 17.3 somthing
spare tire and jack is out..
and since someone stole my stereo, i think i'll be a lil faster.... but when i goto the track, i like to see how my car runs, as it sits on the street... the only thing thats diffrent is that on the track, they dont let me run with the top down
believe it or not running with the top up is probably better. with the top down you start to parachute. in other words. air comes up over your windsheild and drops behind your head and hits the beack seat. It holds you back. Plus it's safer. If the guy next to you shreds a tire and he's out in front, guess who's gonna get a hot piece of steel belted 255/60r16 slapped right across their cheek. OOOOOOWWWWWWW.
Car: 1991 camaro RS
Engine: 305 Carb
91RS4life. Are you sure you gained 13 horses just by regapping your plugs? did you see those results on a dyno?
wheel dyno confirmed 7 horse gain. Engine dyno confirmed 13. Using 1.94 heads and a 4.040 bore. Thank you for asking.
It's a standard trick I use on all my cars and I never see less than 3 hp increase at the wheels.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by 91rs4life
14.774 @ 119 m.p.h. using a 305 with no work.
Car: '90 RS
Engine: 377 LSX
Originally posted by 25THRSS
you are smoking crack if you think you are gonna be trapping ANYWHERE near 119 mph in a stock 305, not to mention that if you did you would be running close to 10's, not 14.7. Somebody is full of ****.
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I made a time of 14.774 @ 119 m.p.h. using a 305 with no work.
No seriously... there's no way on earth.... pffffhahahahahahahahahahahahahahahahahahaha
*rolls over and dies*
You seriously just made my day at work a little brighter.
I 14.774 @ 119 m.p.h. using a 305 with no work.
I hit the wrong button for cripes sake I meant 11.774 (now is where you look at your keyboard and say, "oh yeah I see how he could've done that."
Actually I'm lying, I'm lying about the whole thing. Even though the motor was stock...now my tranny (aluminum power glide)and rearend (richmond 3:23 posi using aluminum alloy bowtie axles) weren't and I got the weight of the car down to around 2800 lbs if I remember correct. maybe 2900 I don't remember for sure. Plus I did run open headers (which I don't consider that a motor mod. I look at it as an exhaust mod. so you're saying high 11's isn't feasible huh? well okay then I'm a liar
I'M LYING
<<< that's me MR. BS Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
91rs... you are so full of crap there's no way....oh wait I'm 91rs4life...I forgot
I'M LYING
I'M LYING
<<< that's me MR. BS Senior Member
Engine: 5.0L TPI
Axle/Gears: 3.08
Taking off weight down to 2800 lbs and running straight headers will get you nowhere close to that speed. If it were that easy, we'd all be doing it.
Lets think about this... if I do it your way, I should be able to take some weight off, run straight headers, get new gears and a new TBI and be in the 9's right?
w00t!!!111
w00t!!!111
I would love to show you. take a camera film it, upload it and send it to your email but, I don't have the car anymore so I won't sit here and continuously argue about whether or not I did it. I do have something to prove but, I can't prove it. So I'm stuck against a wall. this forum is in your favor and I'm a liar. Now stop focusing on me and answer the topic of this thread. I gave my tidbit and if I knew it was gonna start all this I would've never posted it. I'm not mad. It's more like, "well they don't believe me. so what. I know what I did. My witnesses saw it and it was an amazing feat." I got my satisfaction the day I went to the track with it. The people that said it couldn't be done then learned their lesson that day. I'm sorry you weren't there to see it. My point at that time was that I can get a stock 15 sec camaro to run 12's without engine work. They laughed too... Now they copy my tactics. Good Luck with all of your projects out there.
What if I told you about a 10 sec cutlass? or a 10 sec K car?
Email me if you would like to see those.
91rs4life@comcast.net
Car: '90 RS
Engine: 377 LSX
I geuss you have to understand where we are comming from. You should submit your car/video/proof to the book of world records because no one in this wolrd has gotten a stock internal 305 to run 11's. Even 2000 lb civics need 350 to 400 hp with spray to run low 12's high 11's. And I know you car isn't 2000 lbs. Even if you had the unibody stripped and just had the motor in the thing and thats it still seems far fetched. Now if you had a stripped unibody with a heads and cam and what not on the 305 than sure. I 'd belive it then. I am really not trying to hate on you man it just that there are people on here on thirdgen with 350 TBI's fully worked with heads and cam and the best tuning out there, massive weight reduction, and serious drag set-ups and they only rrun high 12's low 13's. I don't like raggin' on people but I geuss this one struck a nerve. I take it on your '83 you had carb, or did u switch to TBI since you posted here.
BlackphantomZ28
Aug 22, 2015 01:00 PM
