whats the best way
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
whats the best way
what is the best way to change the spark plugs on the passenger side? because it is very hard to get to them with all the smog stuff there. would it be easier to go under the car or ? any advice would help thanks. and is there any way to cut down on the smoke at start up because the valve guides are bad.thanks
Car: 1992 Firebird
well i had my car in the air b/c i was changing my brakes and rotor and from the bottom it looks like i can get to the back and i can get to the front ones from the top. i dont see why they cram every thing right there. i guess just to **** people off that have big hands so they cant get to it.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I don't have AC, heater, SMOG, and I can get all 8 from the top in under 15 mins easy....
Remove that **** lol
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Originally posted by Dewey316
i always do all 8 from the bottom.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Go on Ebay and buy one of those modified sockets to accept spark plugs with an open wrench. When *** works on his car he uses this tool. You can get around every primary tube without a problem. I still got them from undernieth but it was sooooo easy with this tool. You could also make your own.
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
When I had manifolds I did too. The hooker headers make it tricky to do a few of them, I just swear until they come out
