Baffled
Old Oct 5, 2003 | 01:14 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
Baffled
My car died last night at 3 in the morning (talk about good timing) it sputters and stalls and is real hard to keep runing but will run if over 3500 rpm if I go below that it sputters and stalls and is verry hard to get running. It backfires out both ends. all my gauges are indicating fine. I played with it for a while this morning and had no luck. I wenk to check the timing and found that with the advance wire disconected it runs ok, like a car with no advance, but it will run and idle. reconnect the wire and it will barly start, the timing is set at 4 deg. the car has run great for 10k miles on the new enginge.
Anybody have any idea what could be wrong?
Any help would be much appreciated
thanks Ryan
Old Oct 5, 2003 | 01:33 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Bad distibutor module or bad distributor pickup coil.
Old Oct 6, 2003 | 12:36 PM
rad8tion's Avatar
Engine: RAMJET 350
I'll try changing out the distributer today
thanks
Ryan
Old Oct 6, 2003 | 12:42 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
you say that with the esc disconected it ran fine, i wouldnt rule out the computer.MHO
Old Oct 6, 2003 | 12:45 PM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
did you check the ground wires on the back of the passenger head... are they hooked up? i had a similar problem when i put in my headers. i forgot to bolt it up
Old Oct 6, 2003 | 06:20 PM
rad8tion's Avatar
Engine: RAMJET 350
well I changed my distributer and it is running fine right now
thanks for the help
Ryan
98_1LE
Feb 22, 2024 10:07 PM
1992Z28!
Nov 19, 2015 07:33 AM
Giocio
Oct 1, 2015 12:20 PM
abray1
Sep 14, 2015 08:18 AM
Eightyninef
Jul 7, 2001 09:37 PM
