Lost!
Old Oct 7, 2003 | 09:18 PM
Ivon1877's Avatar
Car: 1990 Camaro RS with T-Tops
Engine: 312 TBI(305) 0.040 over
Transmission: out of a v-6 s-10 blazer!
Lost!
I have been looking at changing my cam since i started my rebuild back in um? Well when ever it was.
I have been researching a couple of options
1. an LT1 cam
2. L98 cam
or
something custom (not to likely)
What I have is
305 TBI bored .40 over something like 312 ci
Hoping to get a set of headers!
I just want this car to be a cruiser!
No computer problems!
I read about all of the swaps, search everyday, but still lost.
I am intrested in hearing what cam you have and the Pros and cons of doing that swap. Where the power band moved to,ETC.
I would like to keep the low end power!
Old Oct 7, 2003 | 09:49 PM
25THRSS's Avatar
If you just want it to be a cruiser and not have computer problems then I would just stick with the stock cam, maybe even get some 1.6 rockers to raise the lift a little, but you wont have any problems with it and the low end will still be nice.
Old Oct 8, 2003 | 01:04 AM
vjo90RS8's Avatar
Car: 2002 Z28
Im running 1.6 Federal Mogul rocker arms (stamped steel) $64 and advanced my timing from 6* to 8* and gained alittle bit more than 2 tenths and about 1 MPH at the track.
Old Oct 8, 2003 | 12:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you put any cam in there larger than stock you will need to do computer work. If you just want a cruiser, stick with the stock cam and add a full exhaust, intake and a couple other goodies and you will be good to go. That is where my car is at right now. The only thing left to do (which is about to be started) is add some heads and that cam I have laying around. You can only over bore a 305 .030 over just to let you know. You would most likely need computer work with that as well.
Old Oct 8, 2003 | 12:06 PM
25THRSS's Avatar
you can bore a 305 as much as .060 over, but .040 is the most you want to safely go.
Old Oct 8, 2003 | 01:29 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Really? I thought because of the close proximity of the water passages you could not safely go beyond .030 on a 305. Now I know 350 blocks can go .030, .040, and .060 but I thought the 305's (besides bore size) also differed drastically in the cooling passages as compaired to the 350.
Old Oct 8, 2003 | 03:45 PM
deadtrend1's Avatar
a LT1 cam swap is not the end of the world with computer, i ran my stock chip for a long time after the LT1 cam swap i did. Just had to bump up the fuel presure a bit.
Old Oct 8, 2003 | 05:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
id say the lt1 cam as well... Some of the earlier L98 cams werent bad, either. Itll do ok w/o a prom but itll definatly help. Ive driven my car close to 40k with the stock bin and it works pretty well. Hopefully next weekend will have some decent weather so i can finally get out and make changes to the stock programming.
Old Oct 8, 2003 | 06:14 PM
Ivon1877's Avatar
Thanks everyone! Please keep the Info coming! i cant wait to get my crank kit to start the reassembly of my motor! Hope fully it will be here by the end of next week!
Old Oct 13, 2003 | 06:44 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I just thought I'd mention that the stroking kit to make a 305 into a 334-335 engine includes a new crank and boring it .040 over....you could always do that.
Just a suggestion.
I heard that you could bore a 350 as much as .090 over, and a 305 as much as .060 over...
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
