New dyno numbers...
Old Oct 11, 2003 | 10:08 PM
Slade1's Avatar
New dyno numbers...
**261 ft/lb of torque 178 HP to the rear wheels**
cut out open
**258 ft/lb of torque 164 HP to the rear wheels**
cut out closed
Improvement from last dyno run 258 ft/lb and 155 HP. Only mods, ram air design 2, custom y-pipe and cutout, aluminum driveshaft, KYB shocks/struts/4th gen rear springs and SLP take out posi. The dyno pic has an old dyno run from last year before the aforementioned mods.
HP peak is now at around 4800 RPM. Improvement from 4200 peak.
Didn't get a chance to do headers again this year, oh well next year.
Last track run (slipping transmission/broken shifter/no more tread on tires/crappy good for no traction track)
60 ft 2.2-2.5 range, almost identical trap speeds 92.5-93.5 mph
consistent 15.4xx times
15.41x @ 93.5x MPH
The car as it stands mod wise
LO3 305 TBI Auto 350 000 KM/217 000 Miles on the whole car
Stock heads
Stock intake
Stock headers
Stock cam
Smog pump intact
Air conditioning intact
Comp Cams 1.6 Pro Magnum Roller Tip Rockers
Jeg's 1/4 inch Fuel Injector Spacer
March Power and Amp 2 Piece pulley kit
Custom y-pipe with pre cat cut out (slp copied design)
Magnaflow hi flow catylytic converter
Flowmaster 80 Series
1LE Aluminum Driveshaft
6 degrees advanced timing
Custom ram air scoop/modified air cleaner box
MSD GM Blaster Coil
MSD 8.5 inch wires
AC Delco Plugs gapped to .045 inch
K&N filter
Torque converter lockup switch
180 degree thermostat
Wonderbar
KYB GR2/Gas-a-just
16 inch Iroc-Z rims
3.23 Richmond Gears
SLP take out posi
Old Oct 11, 2003 | 11:02 PM
Slade1's Avatar
Dyno pics
Old Oct 11, 2003 | 11:03 PM
Slade1's Avatar
drag pic
Old Oct 12, 2003 | 05:51 AM
25THRSS's Avatar
Good times and #'s. It also shows how with very ltitle work, an L03 can pull way past the so called 4000 rpm wall that everyone talks about. I dropped .5 tenths shifting at 5000 rather than 4400 rpm. TBI has no problem making upper rpm power like tpi does.
Old Oct 12, 2003 | 10:10 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I second that. Very nice numbers
The L03 actually has a lot of potential. I ran 15.7 @ 91.44mph with out even lifting a valve cover on the old 305. Only mods at the time were msd ignition, aluminum driveshaft, 3.73s and posi, and full exhaust (albiet crappy single 2.5"), open element w/ fram filter, and a reletively untuned chip. That was shifting at 5,000rpm as well (t-56).
Crazy thing is, those are awesome times, yet you still have "big" mods you can do. I really think that an intake swap and headers will bring your traps up at least another 3-4mph. After that, a higher stall will help improve those those times given you hook up.
Keep up the good work!
Old Oct 14, 2003 | 10:14 AM
Slade1's Avatar
My next goal before jumping the "big mod" train is to get my torque curve to flatten up a bit. As I hit HP peak I lose 50 ft/lb of torque. I think if I can get it to go more level until I hit that air flow wall (intake/heads/cam) I can pull it close to the 190-195 hp mark.
No doubt that the headers are the next big thing. The ability to get the exhaust out quicker rather than its current state of forcing air out the exhaust should bring the torque up in the mid range 3000-4000 rpm. You can see how the slope drops dramatically on hp after 3200 rpm. This more than anything is the exhaust holding it back. Bringing the hp slope up should really affect the times and mph. with my hp peak now at 4800, I'm only crossing at the 4000 rpm mark. There is plenty of room here to work with. For the stock cam, I think 3.23 gears are perfectly suited.
A 200 HP fairly stock LO3 doesn't seem quite out of reach now does it?
Old Oct 14, 2003 | 02:52 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
when i added headers to mine it really woke up the top end alot. you loose a bit down low but i think that its well work it. my ca with stock cam/ heads untouched goes good until around 5k or so and the headers made a huge differance from about 4k to 5k. I wish i could get my car dyno'd to give you some numbers, but youll be really happy promise.
Old Oct 15, 2003 | 08:42 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I find it amazing that you have such little hp to the rear wheels(considering your ET's)....I would've thought you'd have more.
Not MUCH more..but 178 isn't insane or anything...
It might sound like I'm bad-mouthing your car or something...I'm not, I just find it amazing that you can get it down there so quick with so little improvement.
Basically, that's frickin awsome.
Old Oct 15, 2003 | 09:38 PM
Slade1's Avatar
Now if I could only get the et's to match the damn trap speeds, then all would be fine with the world...
Old Oct 16, 2003 | 01:03 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Good numbers, I can't believe you're getting that on cast manifolds. If you guys remembered, I got 178 RWHP and 271 RWTQ on the stock cam, heads, intake and TBI. I'm glade Slade is backing up my numbers. I ran 14.7s @ 93 mph with this combo.
Personally I think the cam is more limiting to upper RPM power than anything else. The penut cam is tiny, I think acceptable lash limits in solid lifters is similar to what actual lift the peanut cam makes.
Just a warning, once you change the cam, chip tuning is neccessary. I lost a lot of torque below3400rpm and gained after that. (search for my dyno graphs on this forum)
If I were you, I'd do the headers, then intake manifold and suspension/tire to get that thing run mid 14s at 94-96 mph with stock long block and street tires. I'd wait and do the heads and cam at the same time that you plan on spending some serious money on the engine.
Old Oct 16, 2003 | 01:28 AM
iroc22's Avatar
93mph trap sounds good to me. People forget it's a SBC just like every other one.
Old Oct 17, 2003 | 11:52 AM
godspeed's Avatar
Car: 1990 9C1 Caprice
Engine: L05 5.7L TBI 350
Transmission: 700R4 w/ 1st gear lock out
Thats Amazing! You have given me hope. I don't drive a F-Body, but I don't see why I couldn't be pulling the same numbers as you. My mods are in my sig, and I have alot planned this month. I've been tring to get 1/4 mile numbers on my car for the past 10 weeks, but it has rained every Friday since I have tried. Ifs raining now but looks to clear up around 2 or 3 so Racing at 8pm maybe possible. Thanks for the good info.
Old Oct 21, 2003 | 02:58 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
actually, that time's about right for the hp. i'm running 15.94 on 164 rwhp and 253 lbs ft torque. i picked up 6 tenths going to a 3.42 posi, but am still losing short times to a bog.
then there's the "magic run" that comes out of nowhere. i was at the georgia fbody association shootout the weekend before last. there was a kid there with a stock tpi camaro that i ran against half a dozen times during time trials. he ran 15.80s and 15.90s all day. then, out of nowhere, he ran a 15.50. he couldn't figure out why and couldn't duplicate it. it just happened.
Old Oct 21, 2003 | 08:01 AM
godspeed's Avatar
I just ran my Caprice with the mods listed last Friday and turned 15.1@89+ mph. I really wonder why your ET's arnt lower.
Old Oct 21, 2003 | 09:27 AM
Slade1's Avatar
Traction? The tires will spin and the rear will worm on me on launch (that is really funny sounding coming from a 305 TBI now that I think about it). It's not as dramatic as a torque beast like a 383 stroker doing it, but it does it long enough to really hurt my 60 ft times. I stuck my 15's with winter tires back on a day ago and got them to chirp on the 1-2 shift. Mind you though the 15's are aftermarket rims and are lighter than my stock 16 rims so I freed up some torque and lost a bit of traction from the size drop 245->215. I'm tempted to take it to the track with these tires, but I don't want to buy new winter tires.
Old Oct 21, 2003 | 12:32 PM
Engine: L03 305 TBI
if you have any kind of a decent tire on the back, you should be able to hook up with the hp/torque you're making. i'm running stock formula wheels and michelin pilots.
where you're running can make a big difference, too, though. i took my car to atlanta dragway right after getting the 3.42 posi installed. after experimenting, i found that 25 lbs in the rear tires and launching at 2300 rpm worked best.
two days later, i took it to silver dollar dragway in reynolds, ga and had more grip than i could handle. i ended up running 36lbs in the rear tires, backing off the timing 2 degrees and launching at 2500 rpm. the car still bogged, but had the best 60' times ever.
Old Oct 21, 2003 | 12:38 PM
Engine: L03 305 TBI
p.s. your problems aren't in the launch, anyway. while 60' times with street tires in the 2.0 range are most desirable, 2.2s aren't bad and are pretty typical of cars in your hp/torque range. my best so far is a 2.87.
where you're booming is the mph. i was at 82-83 mph before the gear/posi swap. now i'm at 84-85. 93 mph out of your l03 is great.
Old Oct 21, 2003 | 09:31 PM
Slade1's Avatar
I'll take a shot at it next year with fresh tires on my iroc rims. New tires + a decent track should shave off some time for me.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
