could a burnt spark plug wires tripin code??
Old Oct 13, 2003 | 12:31 AM
92 z28's Avatar
hey, ive been getting code 43 "43. Low voltage at electronic spark timing circuit" a couple weeks after i installed my headers, full exhaust, and full emmisions delete. i thought it would be the knock sensor so i changed it. the car was running ok for a couple hours, then when i romp on it the code tripped again, and im pretty sure the car retarded the timimng. after i installed the headers im pretty sure i damaged/burnt some spark plug wires. is it possible that damaged plug wires would trip #43? if not,,, WHAT AM I LEFT WITH HERE??? thanks.
its an lo3
Old Oct 13, 2003 | 01:09 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I have the exact same situation, except I don't have headers, and I'm absolutly sure they're not touching the exhaust manifold...so I'm guessing that no, the wires don't ahve to do with it.
I could be wrong though.
I would like to know more about this too, its driving me nuts...especially sense it kinda surges sometimes trying to adjust the timing back to normal...oy.
Old Oct 13, 2003 | 08:16 PM
Crisis's Avatar
hmmm...
My spark plug wires wern't burnt but very old and were around 3 ohms measured... should be around 14-15 ohms
that did trip code 43...
Hope this helps...
Old Oct 13, 2003 | 09:28 PM
FreeLoader's Avatar
Transmission: a
hmmness....
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
