LT1/LS1 Cam in 91 L03 305
Old Oct 17, 2003 | 12:36 AM
tckeeper's Avatar
I have a 91 TBI LO3 with an Edlebrok intake, custom exhaust and 3.73 gears.
Is it possible to replace the stock cam with an LT1 or LT4.
What additional things would I need to do to ensure computer compatibility?
Old Oct 17, 2003 | 06:14 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
any swap that changed the air flow of the engine will cause the computer to need to be changed. since our cars are speed density, they are more touchy to changes that the MAF cars are. the lt4 cams are rather large, not something i would swap without doing heads at the same time. read the DIY-PROM article from traxion on this site, and start reading on teh diy board. see what you have ahead of you for tuning.
Old Oct 17, 2003 | 10:07 AM
vjo90RS8's Avatar
Car: 2002 Z28
make sure it is an LT1 cam, you CANT use one from an LS1
Old Oct 17, 2003 | 10:18 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
He is right on this one. You can use any cam from a gen one or two block but not the newer gen 3 (LS1 series) engines. All LT1/LT4 cams have a loger dowel pin on the end of the shaft that needs to be cut off or pressed in. The LS1 cams are completely different in every way shape and form. The production LT4 is about as big as you can go on stock heads. That is with 1.5 roller rockers which puts its lift right around .450".
Old Oct 23, 2003 | 07:32 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
im goin to put lb9 heads which are the 5.0 tpi heads and a lt1 cam with 1.6 roller rockers and put screw in studs on the heads so im going to see like 50 hp gain and a manifold to
Old Oct 23, 2003 | 12:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will need to have the spring seats machined to accept that cam with 1.6's. If not you will have to do some close measuring to make sure that there isn't any coil bind. Also, are you going to port those heads and tune your own chip. If not you won't see anywhere near 50hp gain. If you fully tune, have a really good port on those TPI heads, or go for an aftermarket brand, and good intake with proper fuel delivery, then you may see 50hp.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
