Upgrading lines pump for future?
Old Oct 21, 2003 | 07:10 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Eventually, I was thinking of changing to a high pressure form of fuel injection, (I know TBI board doesn't like that). I like to space my projects out, so here is my question: Can I change all my fuel lines and pump and get the pressure down to work with TBI until I change injection/ engine without to much work? Has anyone else done this?
Old Oct 21, 2003 | 10:48 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
yes and yes. I, and several others are running the Walbro 255. I run the high pressure unit capable of 90psi or something. The pressure regulator will take care of the fuel pressure
Old Oct 22, 2003 | 01:11 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Yep, the walbro is where its at I dont know if you have to change lines though, I read that the stock ones were capable of flowing ~500 hp, but obviously I dont have first hand expirence.
Old Oct 22, 2003 | 07:06 PM
Engine: LO3;383tpi
You definetely want to change the rubber hose going from the sending unit to the pump with a new one with a braided sleeve. I found this out the hard way. It's also the time to check the sending unit lines.
Old Oct 22, 2003 | 10:51 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Im tryin to remeber what my kit came with. A new o-ring, rubber collar type thing and then a new rubber hose, havnt had problems with it for about 1k miles.
Frozer!!!
Jan 19, 2024 04:55 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
Kaweh
Aug 9, 2015 02:54 PM
