GM Aluminum TBI intake manifold
Old Nov 12, 2003 | 02:58 AM
joshwilson3's Avatar
Old Nov 12, 2003 | 07:26 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
That manifold looks no different than all the other Fcar TBI aluminum intakes.... so it's probably identical to the one on your 305 engine.
See
https://www.thirdgen.org/techbb2/sho...light=10166133
and note that the casting number in your picture is 10166133, not 10166137. Also, the casting number isn't always the same as the GM part number. FYI.
Old Nov 12, 2003 | 09:55 AM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
I can also tell you that manifold has been listed on E-bay several times but the reserve never seems to get met. Don't get is as a replacement for yours.
Old Nov 12, 2003 | 12:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is a standard GM TBI intake and there is zero things special about it. Both are aluminum by the way. I think this one has just had its black paint removed.
Old Nov 12, 2003 | 12:34 PM
Old Nov 12, 2003 | 12:37 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i suggest you save $100 more, and get something that will benifit you. or look for a 4bbl performance manifold on e-bay.
theshackle
Aug 22, 2015 06:52 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
