Engine options for a 91 firebird
Old Nov 15, 2003 | 06:53 AM
Jay1's Avatar
Car: 1991 firebird
Engine: 305 tbi
Transmission: tremec 3550 5spd
Currently i have a 91 firebird with the 305 tbi.ive done everything i can to the car and some to the engine.The car has
1.Tremec 3550 5spd
2.auburn posi w/3:73 gears
3.Steve spohn driveshaft,subframe conns,lower control arms.torque arm,panhard rod.
4.tokico illuminia 5 way adj shocks
5.eibach springs
6.suspension tech sway bars
7.centerforce dual friction clutch
The engine has
1.March underdrive pulleys
2.edelbrock intake,water pump
3.Crane cams ignition,coil,gold race rocker arms,compucam
4.Hypertech chip,fan switch,thermostat
And much more but my question is what can i do for engine replacement?What engine should i go with.What should i do with the induction?The computer?Keep it or ditch it?I want to put in something around 350-400hp whether it be a 350 or 383stroker Any ideas??????
Old Nov 15, 2003 | 02:51 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
I'm building a 388ci with a 700cfm Holley 4bbl TBI, thats ran by the GM ECM. Ditching the ECM and going carb would be easy.
Old Nov 15, 2003 | 03:50 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If money is not a limiting factor I'd go all out 383 with a stealth ram setup.
jhawkeye
May 25, 2022 06:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
