Are 3.08 gears bad?
Old Nov 28, 2003 | 12:24 AM
5speedrs305's Avatar
Are 3.08 gears bad?
I am not sure if this is correct but I "think" my car has the 3.08 gears, are these good gears? Pro's-cons about them? Are they good for top end or low end tor?
Old Nov 28, 2003 | 12:34 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well, they are better than 2.73's
they are a top-end gear (well not really, i can explain more if you like, but in our cars your top end will likely be higher with 3.42's) they are more of a fuel econemy gear.
Old Nov 28, 2003 | 12:36 PM
iroc22's Avatar
3.08 gears are great for a stock, or near to stock L03. You can use more of your power band with a higher (numerically lower) gear.
Old Nov 29, 2003 | 12:53 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
depends on the combo...
Bubbajones_ya
Aug 28, 2015 02:17 AM
Regal105
Aug 23, 2015 03:45 PM
InfinityShade
Aug 22, 2015 08:00 PM
