In the 14's, post your combo here
Old Nov 30, 2003 | 10:56 AM
JPrevost's Avatar
Car: 91 Red Sled
Post your combo here!
Old Nov 30, 2003 | 12:53 PM
vjo90RS8's Avatar
Car: 2002 Z28
14.791@91.11 MPH w/ 2.068 60'.....these times are without the new tranny and torque converter
Old Nov 30, 2003 | 02:02 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Times and mods are in sig, I am in the process of building another 350 that will have 330 hp and 410 tq and will hopefully put me in the mid to low 13's.
Old Nov 30, 2003 | 06:53 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Last time I gtech'd, I got a 14.7, thats with no 3rd gear over 1/3 throttle (crappy tranny). FIxing stuff right now, and some new parts and better tranny and stall, I'm looking for an uncoreccted time in the high 13's (with open headers).
Old Dec 1, 2003 | 10:54 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Close enough...
LT1 cam, Vortec heads, Performer RPM intake, BMR sfcs, BMR lcas, BMR relocation brackets, BMR adj phr, Walbro 255 high volume fuel pump, b&m 2400 stall, stock tbi, stock injectors, 3.42s, posi, falken 275/40/17s, Hooker 2055 headers, catco 3" in/out cat, Flowmaster 3" catback and a stock wot chip, with some timing tuning and partial throttle tuning.
It went 93 mph before the fuel pump, but I only ran that twice as my pump started to die. I got a 454 tbi waiting to go on, too lets hope for 13s with tuning!
Old Dec 1, 2003 | 11:32 AM
rsilver's Avatar
see my sig for mods. I wonder about the trap speed on the g-tech but my speedo is over 100mph and my launches are very poor. No traction on streets. I may get into the 13s once I get the WBO2 for WOT tuning, but that my be a dream . Power curve gets real flat at 5,000 on the tach.
Step one: Max what I got with the correct afr @WOT
If I pull to 5500 and knockoff 1 or 2 tenths, I am done.
Step two: If no improvement, go to a 4bbl/single plane and re-tune and hope for improvement.
I am probably in the high 13s at sea level, @ 6,000 feet I am definitly slower.
Old Dec 3, 2003 | 12:14 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
the sig is where i was before header/exhaust install.
went against conventional wisdom, and i think i may have hit a small jackpot.
went with slp 1 3/4" headers (w/ air tubes)
dual 2 1/2" cats
awesome custom mandrel-bent y-pipe and 3" cat(s) back.
flowmaster muffler and dual 2 1/2" tailpipes tucked up under the car.
the stock 02 sensor works fine, it idles at 600rpm, and is actually quieter than before (and it's the same muffler!).
more importantly, i'm not experiencing any of the bottom end torque loss i feared with the big tube headers and more free-flowing exhaust.
i have a serious wheelspin problem now where it bogged before. get best 60' times by launching at around 1,500 rpm, waiting till the tires hook, then nailing it. still only in the 2.3-2.4 range. there's a lot more et improvement in lowering those 60' times.
times on the g-tech have varied from 15.30s all the way down to several 14.90 runs. prior to doing the headers, i ran the car down the dragstrip and on the g-tech simultaneously. it was close. the car feels a lot faster now, i think the g-tech is pretty accurate.
comparing the tach to the g-tech memory shows my factory tach to be right at 500 rpm slow. i've gotten my best times shifting at 4000 on the tach. the g-tech memory shows the actual shift point to be at 4500. winding it higher makes it slower.
i'm taking the car to the dyno thursday night to see what the hp/torque changes are. won't be able to get real track times on the car till january. : (
SECRETS TO GETTING ACCURATE G-TECH TIMES:
1. accurate weight. I weighed my car with a full tank of gas and me in it ... 3775lbs (i weigh 275)
2. did the g-tech setup inside, on a flat table, with a level. it corrects to .00, .01 now in the car
3. set rollout to zero. there's a section on rollout in the manual. it makes it clear that the more rollout you set on the unit, the faster the times will be.
Old Dec 3, 2003 | 01:39 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
vjo beats me?!?!?!?!?!
times were with out the holley tbi, weiand intake, msd box, and fuel pump.
performer tbi intake was on
Old Dec 5, 2003 | 05:48 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Vjo:
Do you have the stock heads and cam in there?
Old Dec 5, 2003 | 12:13 PM
vjo90RS8's Avatar
Car: 2002 Z28
yup, stock heads, cam, intake and tbi, and 161K miles on the engine
Old Dec 5, 2003 | 03:08 PM
cali92RS's Avatar
Car: White KSwisses
I guess suspension really does make a huge difference.
Old Dec 6, 2003 | 08:30 PM
RichSoucie's Avatar
14.162 @ 92 mph bone stock 86' IROC-Z
Old Dec 12, 2003 | 12:46 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
See sig for 305 TBI with stock un-touched heads.
Old Dec 12, 2003 | 01:47 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
y does beast have a better 1/4 than me and i have more power. 199hp, 293tq what suspension u got.
Old Dec 12, 2003 | 01:59 AM
Engine: LS7
What was your mph? what was your 60'?
My TBI car has stock rear shocks( as far as I know and KYB struts(cheap ones)) stock everything else(IROC sway bars). Raced on GTA crosslace wheels.
Race weight is ~3500+ lbs.
Maybe the gears help, 3.73s, also, my power band is ~600-800 rpm higher, 4400-5200 rpm (~190+ rwhp) I think.
Weight, traction, gears,and shifting(shift points). I wouldn't shift any higher than 4500 rpm or so in your car. Traction should be the major factor. 2.1x 60' vs 2.2x 60' equals .2-.3 sec in the 1/4.
Old Dec 12, 2003 | 02:29 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
yeah i think that was my problem, i was shifting at 5000. but my dyno now shows i should shift lower.
14.97 1/4
2.180 60
92.49 mph
Old Dec 12, 2003 | 09:44 AM
Dr. Suess's Avatar
Car: 1986 Chevy Camaro IROC-Z
ok guys i just found a time slip
14.123 @ 82mph with a reaction time of 1.123 sec cause i was backing up for the stage lights to go on and the lights started to go and then i missed the 2 to 3 shift this was a really messed up run how did i keep my time so low
Old Dec 12, 2003 | 11:28 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
14.123 @ 82mph with a reaction time of 1,123 sec cause i was backing up for the stage lights to go on and the lights started to go and then i missed the 2 to 3 shift this was a really messed up run how did i keep my time so low
something doesnt seem right there...
Old Dec 12, 2003 | 07:17 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The only way you could have a 14.1s @ 82 mph, is to have about 400hp, and hit the brakes hard in the last 60 ft.
Old Dec 12, 2003 | 09:28 PM
25THRSS's Avatar
He said he missed the 2 to 3 shift so that explains it.
Old Dec 13, 2003 | 05:48 AM
vjo90RS8's Avatar
Car: 2002 Z28
i think he subtracted his reaction time from the 1/4 mile time or something, damn newbies hahahahahaha, now way he is hitting those times with that trap.
Old Dec 13, 2003 | 07:58 AM
Engine: L03 305 TBI
30mph rolling start
Old Dec 13, 2003 | 08:38 AM
Dr. Suess's Avatar
i just realized this is the TBI board i have TPI and i usually run about 12.5 seconds
Old Dec 13, 2003 | 02:00 PM
Engine: L03 305 TBI
try again when you a) hit puberty and b) get a driver's license.
Old Dec 13, 2003 | 02:03 PM
Dr. Suess's Avatar
what the hells that all about just because i was on the wrong board
Old Dec 13, 2003 | 10:18 PM
steve8586iroc's Avatar
Dr. Suess, you might want to add your sig to your post or at least tell us what kind of mods you have. I don't think anyone that has responded to your post realizes you are not running a stock 350tpi setup.
Steve
Old Dec 13, 2003 | 10:21 PM
Engine: L03 305 TBI
i don't know of any setup in the world that runs a 14.1 at 82 mph. my best time so far is a 15.92, and i was running 85mph when i did it. you'd need a 60' time of about 1.0 to get a 14.1 out of 82 mph.
Old Dec 14, 2003 | 06:04 PM
That's not necessarily true. If you are running a faster et and brake before the fishish line you will do the same thing. Or if you have a good run throught first and second gear and miss third you can do it as well. If your car is capable of better et's that is.
Steve
Old Dec 14, 2003 | 06:25 PM
Engine: L03 305 TBI
Steve
he says he usually runs 12.5s, but missed 2-3 shift and ran that, so he posted that 1 run in the 14 sec post?
come on! you brag about your fastest times, not your slowest.
Old Dec 14, 2003 | 06:31 PM
Dr. Suess's Avatar
the topic is in the 14's post here so that run i was in the 14's
Old Dec 14, 2003 | 06:36 PM
Engine: L03 305 TBI
whatever
it's been days since someone asked you to post your combo. where is it?
Old Dec 14, 2003 | 06:45 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Dr. Suess, If you do own a car, please post your setup.
Old Dec 14, 2003 | 07:00 PM
Dr. Suess's Avatar
all i know is that it is a 400ci 6.6l TPI with vortech heads i bought the car like this from a guy up the street it had alot of problems but the engine was new so after i fixed all the electrical and body problems and finally got to drive it the guy had moved and could not ask him what he had done to the engine i am assuming he bought it built this way.
Hotrodboba400
Dec 10, 2019 07:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
mrdevontay
Sep 2, 2015 08:04 PM
z28guy134
Sep 1, 2015 11:50 PM
