what temp for closed loop?
Old Dec 1, 2003 | 09:59 PM
Charlo's Avatar
Still messing with an engine conversion. I am trying to get her to closed loop and to get the TCC to lock up on my 7747 bigblock(7.4). VSS and neutral/safety and O2 are functioning properly. I got 3 questions.
1. I assume the TCC is not locking up because she is in open loop.
2. I think she is in open loop because of my 180 stat makes her run at 185. (closed loop @190?)
3. Scanner said "knk signal...........NO"
does that mean no knocks sensed? or no knock sensor detected?
charlo
Old Dec 1, 2003 | 10:24 PM
Charlo's Avatar
While searching I found that closed loop occurs @140 degrees so it is not the stat/temp. The ses light is not on and the only stored code is I think 32 which the scanner said was egr. If not the temp what else could it be?
Charlo
Pac J
May 17, 2020 10:44 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
92camaro350cci
Oct 14, 2015 09:29 AM
luvofjah
Sep 26, 2015 08:28 PM
corey8084
Sep 17, 2015 02:56 PM
