Need help: New chips.. car pooped
Old Dec 3, 2003 | 09:50 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
I put a new chip in my car from tbichips.com, it ran fine for a day, now it's screwed up on me. The "check engine" light flashes, and the car idles at about 15-20k RPM. I tried pushing the chip in tighter, and warming it up, but neither worked. Is the chip dead and the car in some sort of safe mode? Or will the car run at all if the chip is not right?
Thanx,
Chris
Old Dec 3, 2003 | 10:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Put the stock one back in and see if you still have problems.
Old Dec 4, 2003 | 12:07 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Those old 2732 eproms arnt that stable after all these years. I tried unsuccessfully to use them. out of the 6 or so that i bought, 5 were dead. The computer is going into 'limp home' mode after the chip bit the dust. Just put the stock one back in, that should solve the problem.
edit: if you want to have a custom chip, you can get the moates adapter and take advantage of being able to use the newer flash rom. I have eeprom and it makes my life alot easier. I dont have to worry about it pooping out and the chips are a snap to reprogram.
Old Dec 4, 2003 | 08:32 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
wats that, where can I get it, and how much does it cost?
Old Dec 4, 2003 | 09:02 PM
Car: 88 Camaro SC
Engine: SFI'd 350
moates.net is the place that carries the 28 pin adapters. 30 for the adapter and another 150 for a burner, but its well worth it considering what you yourself can do. The flash rom can be programmed just by sticking it in the burner and hitting 'program'. Theyre stable because theyre not 20 some odd years old and they program almost instantly.
Old Dec 8, 2003 | 04:18 PM
Ronny's Avatar
i have about 10 #2732. never had a problem. but from what i heard i may be the lucky one. half were from one vendor the other half from another vendor. only issue was not having a insertion devise and in that case i messed up a couple.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
