Installed Edelbrock Performer Carb 3706 Manifold
Old Dec 16, 2003 | 01:50 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Just wanted to pat myself on the back for installing the 3706 Carb manifold, it was a slight pain in the ***, but only because I tend to overcomplicate stuff. I already wrote a "tech article" but the server ate it so I'll be writing another thingy on the little intricacies that come with installing this manifold. Seems to work great, haven't G-teched it yet. It feels faster, but still slow, but then again I've been driving my roomy's 13.4-running 2000 Z28...can't wait for the nitrous to smoke his *** .
Install notes: https://www.thirdgen.org/techbb2/sho...hreadid=214897
Old Dec 16, 2003 | 10:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What were some of the pains? Also what adapter plate did you go with. Anything else that you had to modify? Any pics?
Old Dec 16, 2003 | 07:06 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Pictures soon
Old Dec 16, 2003 | 08:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Sounds like the same step I went through with my intake swap. i will be pulling my intake again tomm so your article will help refresh my memory. Good job man.
Old Dec 17, 2003 | 12:20 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
I just Tazzo'd it today. It pulled 91.7 MPH with a 2.43 60' but the E/T didn't show
I spun really really bad, my sixty foots are normally in the low 2.1 range. The engine was running hot, the O2 sensor was maxed out on rich (I need to turn down the FP) and it hesitates around 4400 (possibly too much timing). I'm going to lower the FP, take out 2* and see what it does. 91.7 is good enough for a 14.8 but we'll see, it still needs a lot of tuning. I'm still kinda puzzled where to shift it at
Old Dec 17, 2003 | 12:42 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
hey tony, great article. very informative.
one question. when discussing the fuel pressure gauge, you said: "This is also a good time to put a fuel pressure gauge in. The TBI cars aren’t equipped with a Schrader valve from the factory, so parts store carry a FP gauge with a little adapter for TBI’s that you put in between the fuel line and the fitting on the TBI, so toss this on, it’s quite useful. My FP is 10 psi at idle and 16 psi at WOT (actually a little too rich). "
where did you get the gauge with the fitting? do you have the part number?
Old Dec 17, 2003 | 12:54 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
I got it at Autozone, but I've also seen it at Pep Boys. There was a thread on it, I'll see if I can find it.
Old Dec 17, 2003 | 01:06 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Actron III GM TBI Fuel Pressure tester kit PN: CP7817
http://www.actron.com/cgi-bin/web_st...17.htm&cart_id
$40 + tax at Autozone
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
